Thread: 4' x 4' x 8" Router Build
01-12-2022 #17
I'm assuming this is something I could easily upgrade if the need arises once I'm up and running? The cables I have came with 3m extension cables, hopefully these will be long enough.
OK, I'll leave it un-connected. The cable from the VFD to the spindle needs to be shielded but with the shielding only connected at the VFD end and not to the spindle connector - is this correct?
I'm referring to the 24V to the isolated inputs, the 24V and 5V power connections to the AXBB-E are permanently connected. Should the isolated inputs be permanent too?
BUILD LOG: Router Build Mk 1
By hoppo in forum DIY Router Build LogsReplies: 19Last Post: 14-08-2017, 08:31 AM -
Router build
By Blackrat in forum Gantry/Router Machines & BuildingReplies: 39Last Post: 18-12-2014, 07:19 PM -
RFQ: Does anyone want to build me a cnc router?
By totally useless in forum Projects, Jobs & RequestsReplies: 31Last Post: 08-05-2014, 09:55 PM -
BUILD LOG: My Router Build!
By andy0202 in forum DIY Router Build LogsReplies: 3Last Post: 31-01-2013, 08:51 AM -
BUILD LOG: A3 Router Build
By GTJim in forum DIY Router Build LogsReplies: 6Last Post: 17-02-2012, 12:53 PM
