    from your description I don't see any thing wrong
    do you have the stepper driver enable inputs connected ??
    if you do
    try running with the enable disconnected
    (the enable is a negative logic input so the drive is enabled with no input !! )
    if Mach 3 is a bit slow enabling the drive that could be a cause of you missing steps
    what position do you have switch 4 ?
    if its off , the motor current will be reduced when the motor is idle
    switched on , the current remains at the 4.2A you set the stepper driver to.
    and you should feel more resistance when you try to manually turn the hand wheel
    John
    PS
    if you have a JPEG photo on your desktop to add to a post
    when adding a reply or editing a reply
    click the symbol marked in red
Name:	add photos.jpg
    on the next page click basic uploader
    to add files from you computer
    next page click browse
    then type the JPEG file name in the box
    Quote Originally Posted by john swift View Post
    I quite agree. Thanks, Richard, for the reply. It does sound as though the steppers are underdriven... but I can't see any cause.Not sure about sw4 - you do say it stalls when operating so half-current setting shouldn't come into play. How warm are the steppers after a protracted period energised?, if not hand-hot then try upping the current setting on the drivers. After that I'm out of ideas.
    You've not got any silly-long lengths of cable in the system?, no dodgy fine gauge cables to drop the supply voltage at the stepper driver?
    Ah, one point - you still have the trapezoidal lead screws... ah - they will put a larger load on the steppers than a ballscrew... but you do use powerful steppers. Nope, I'm out of ideas.
    Lives in Marple Stockport, United Kingdom. Last Activity: 16 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Just my 2 cents worth how big are the hand wheels because they will take a lot of inertia to drive them.
    hello all out there,thought i would try to send some pics of my man cave,hear goesClick image for larger version.
ID:	24467Click image for larger version.
  1. Stepper motor I.D anyone?
    By Nthkentman in forum Machine Discussion
    Last Post: 11-05-2015, 08:03 AM
  2. How do I wire a stepper driver to a stepper motor?
    By swood1 in forum Stepper & Servo Motors
    Last Post: 21-09-2014, 05:40 PM
  3. Replies: 1
  4. Stepper motor help.
    By Kammo1 in forum Stepper & Servo Motors
    Last Post: 12-02-2010, 11:11 AM
  5. Stepper motor help
    By Mucky Mike in forum Stepper & Servo Motors
    Last Post: 04-04-2009, 04:25 AM
