    Hi all,
    I'm having an issue where the Z axis on my yr2000 Triac VMC - Servo (Baldor Servo + drives) 1ph... will drop the Z axis on power off or e-stop. It only does it sometimes, but when it doesn't... touching the head with fingertip pressure will cause the head to drop full [rotates ball screw] until it's at the end of the travel.
    This machine has just been started to be converted; so I've rewired a few bits.
    So... I understand why servos do this... (as opposed to steppers // holding torque etc.). However I am under the impression Triac's do no have a servo brake, or a counterbalance fitted. So was looking at do I need to fit a gas strut to stop my Z-axis dropping.
    BUT: Why should I have to do this? I assume the machine worked perfectly without this, with the original DOS setup. What possible wiring could I have changed which now makes the Z-axis drop on power off? Is there anything I'm missing?
    There were no brake / regen resistors fitted previously to the drives. Do I need to add these in, or are they only for decelerating at high speeds?
    Also, does anyone have any advice on tuning the Baldor servo drives? The defaults were well off. Just wondered if anyone had any tip or direction on this.
    All the best,
    Dan
  2. tighten the z gib screws slightly- to give a bit more friction? mine doesnt drop with no servo power.
    Thanks. Fixed it.
    It was a combination of that and the motor mounting belt tensioner was incredibly loose.
    Also fixed it tuning; it's now really smart.
    I got up to 9,600mm/min rapids, but slowed that down to 5,000mm/min on the X/Y and 1,500/min as any faster was a bit silly!
  4. does your machine orient the spindle? thats the bit im stuck on at the moment
    Quote Originally Posted by battwell View Post
    You mean if it knows the exact angular position of the spindle?
    No...
    Currently fitted is a SEM MT30U4-36 and Sprint 1800 drive.
    That has a tacho on it; but anything better than that i.e. for rigid tapping etc you'd need a new spindle with resolver or encoder and a new drive.
  6. -required for tool changer to align the drive dogs of the spindle.
    original fanuc control did it- but im having trouble getting it to stop in the right position.
    stupid thing.lol
    mine has the control techniques lynx drive- not sprint- so already mains isolated :-)
    Lives in East Lothian, United Kingdom. Last Activity: 4 Days Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    Machines with the drive dogs, IIRC early ones used a drop in solenoid to locate the spindle, then later ones used a sensor (possibly alos with a programmed time delay).
    Denford stopped fitting the drive dogs at some point though, as they aren't needed for the relatively low power spindle.
  8. The Following User Says Thank You to m_c For This Useful Post:
  1. Question on Servo power output.
    By Zadig in forum General Discussion
    Last Post: 24-08-2017, 01:13 PM
  2. Denford Triac VMC Mill with ATC, SERVO drives
    By Ade taplin in forum Denford Mills
    Last Post: 01-08-2017, 01:00 PM
  3. FOR SALE: Denford TRIAC Servo VMC 1PH
    By fidia in forum Items For Sale
    Last Post: 12-01-2017, 09:35 AM
  4. FOR SALE: servo motor + driver + power supply, plate
    By remrendes in forum Items For Sale
    Last Post: 03-08-2015, 08:06 PM
  5. Looking for power info for Fanuc VMC Triac and Cyclone
    By jamesgates1000 in forum Milling Machines, Builds & Conversions
    Last Post: 03-08-2015, 07:30 PM
