    Hi All
    I m hoping someone can point me in the right direction for a weird problem I have with my control.
    Using UCCNC and separate drives for each axis.
    If I try to jog say in Z, the Y and X move together. Some axis will only move in one direction sometimes not at all.
    I have rechecked my wiring and all seems okay to me, I have also changed the BOB.
    Please can someone point me in the right direction for tracing the problem?
    I'm prob barking up the wrong tree but...
    I'd say it's your ports and pins settings myself.
    What are your settings at?
    For instance. If I'm using port 1 for a 3 axis starting from say output pin #2 I would assign.
    Step = PUL , Dir = DIR. #x = pin no.
    X axis= step #2, Dir #3. go to PUL-, DIR- on X driver.
    Y axis= step #4, Dir #5 go to PUL-, DIR- on Y driver.
    Z axis= step #6, Dir #7 go to PUL-, DIR- on Z driver.
    I also always use enable too (generally from pin#14) wired to ENBL- on ALL drivers in parallel.
    5V+ve power line wired to ALL drivers in parallel to PUL+, DIR+, ENBL+.
    Assign pin#14 to output1, then assign enable1 as output1.
    That's generally how I wire one of those generic 5axis boards that use parallel connection at least
    Quote Originally Posted by GREG021 View Post
    Hi All
    You are not saying which UC controller you have, but my guess is that something is wrong with your configuration. Anyway, not enoug facts here.
    Hi Daz
    Thanks for getting back to me.
    That is how I have connected it except the ENBL because STEPERONLINE support recommended it as follows.
    Thank you using our products.
    Our suggestions are as below:
    1. Power Supply: 48VDC
    2. SW1,SW2,SW3: off, off, on; SW4: off; SW5, SW6, SW7: on, off, on ,on
    3. ENA+, ENA- : Keep no-connected
    4. PUL+,PUL-: Pulse edge select Falling edge. as below fig,
    dutycycly: 50%, frequency: 8KHz for a try( 300rpm)
    Also, I have not assigned Pin #14.
    What do you think?
    Hi
    Thanks for your reply.
    I am using Stepperonline drivers with the cheap but Green BoB and setup with UCCNC.
    The motors are the original Denford Easimill ones.
    Does that help?
    Hi
    Does that help?
    This one?
    Pins 2,3,4,5,6,7 from right to left are axis.
    PUL- , DIR- on drivers.
    5V+ from psu direct to PUL+ & DIR+
    (Enable doesn't have to be connected, it's a personal choice. Saves some power use at idle).
    The 2 grounds in bottom corner can be connected together with a small loop.
    Check this is all wired correct like this first.
    The other common bob is same as my 5 axis:
    (single driver Y axis is shown).
    Hi
    Does that help?
    No, it does not help. Stepperonline is NOT a CNC Drive product. I did not mean the stepper driver, but what you have between your stepper driver and the PC. Is it UC3005LPT, UC400, UC100 or what? Configuration is different for all those and the UCCNC license is locked to the product. It is the motion controller I was asking about, not the stepper driver. UCCNC must have a motion controller made by CNC Drive. Without that, you'll never get it working.
    You don't (that I've read) explain if this a new set-up, or a set-up that did work and has now failed - that's kind of important to understand where you are. The question from A_Camera is relevant in terms of UCCNC controller - but that you're using a BoB suggests its not a AXBB, at least. Can you provide that detail as well?
    Your fault description shows a common-mode failure across multiple axis. Yes, it could be a major cockup in the UCCNC configuration - but I'd be surprised. I'd look for a common-mode fault, such as a 5V supply failure (or wiring fault) to the BoB that's allowing it to limp under parasitic power but fails across multiple channels when there's an attempt to draw current - particularly as you describe an inconsistent behaviour.
    For me, I'd isolate the controller from the BoB, and then toggle any single axis "step" pin on the DB25 connector between 5V and 0V (just a wire, nothing special) - for preference through a 1k resistor (just added safety) - if the problem remains at this level it's the BoB, or supply to the BoB.
    EDIT: A photo of your control box could help.
    Hi All
    Thank you all for your help.
    From your comments, I obviously need to give you more information.
    This is a new setup. I bought the machine with a Gecko G540 but the connectors were corroded, so after hours of trying to sort it out decided to start afresh.
    The cabinet contains:
    3 off DM860I stepper drives.
    1 ST-V2 Bob
    1 UC100 motion controller
    1 60 volt power supply
    1 24 volt power supply
    1 5 volt power supply
    Control software is UCCNC
Name:	CABINET LAYOUT.jpg
Name:	Screenshot of UCCNC (X axis).png
    Please excuse untidy wiring just want to get it working first.
    If it seems correct can someone talk me through fault finding? I do have a basic scope.
    I am sorry, I don't have time to talk you trough, but it would help if you'd answered ALL questions, when asked. We are only trying to help. For example, the question about if this never worked or it worked at one time, but now not working any more.
    There is no need for an oscilloscope normally, a simple DVM would be more than enough to check all the wiring. The untidy wiring in itself is not disturbing me, but it is a good source of error. The picture you included is so small, it is for me impossible to see what is connected to where. Did you make a schematic of the connections, or you just started wiring? A drawing would be more helpful than a picture of the wiring in my opinion. Also, the second picture is showing ONE axis configuration, but you are not saying which one. Anyway, how about the other two axis configuration?
    I also assume you bought an original UC100 from a legitimate seller, not one of those fake eBay copies. Those copies may or may not work, but most probably will never really get it right with a fake one.
  1. Stepper motor making a weird noise
    By GeorgeS in forum General Discussion
    Last Post: 09-06-2020, 09:51 PM
  2. Weird Mach3 + CSMIO/IP-M Probe Problem
    By matt-b2 in forum General Discussion
    Last Post: 11-07-2019, 01:05 PM
  3. Help with Problem X axis Stepper Please
    By howser37 in forum Gantry/Router Machines & Building
    Last Post: 09-02-2017, 06:31 PM
  4. Weird problem - stepped/staged deceleration on Huanyang 2.2kw Spindle
    By glynster in forum Spindles & Drive Motors
    Last Post: 25-01-2016, 01:39 PM
  5. weird z axis..
    By dazza in forum General Discussion
    Last Post: 10-11-2014, 01:39 AM
