Thread: Resin vs grout
23-06-2018 #1When epoxy is used it is usually set at about 5mm thick and with about a 5-8 hour settle time so it has a long time to self level. With the West System.METHODS OF PLACEMENT: Five Star® Grout may be dry packed, poured or pumped into place. Minimum placement thickness for Five Star® Grout is 1 inch (25 mm). For pours over 6 inches (150 mm) in depth Five Star® Grout should be extended with a clean, damp coarse aggregate meeting the requirements of ASTM C 33. Refer to Five Star Products’ Technical Bulletin “Cement Grout Aggregate
Extension” for guidelines. For more detailed placement procedures, go to FiveStarProducts.com and select Design-A-Spec™ in product
downloadsA
Looking at the spec above it appears to say it requires a min. of 25mm depth and you add water I would be wary of the shrinkageLast edited by Clive S; 23-06-2018 at 09:18 PM.
23-06-2018 #2
Hi
It is shrinkage compensated, we use it for levelling machines and structures and certain bearings, it's used in a slightly different way, we install and level using jacking bolts, once level a box is built around each foot/ mount which is above floor level, the grout is then poured into the form work until it rises to just above the underside of the mount and left to set, works in that application
23-06-2018 #3
Yes I agree with that but you are levelling the machine first and then applying the grout to the void.
With epoxy you put a moat around the box section frame with a bridge between to two rails and pour the epoxy and then let it self level in order to get both rails on the same plane.
But it would be interesting for you to try it for the benefit of others
Self levelling epoxy resin
By flanagaj in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 21-11-2020, 01:47 AM -
Where do you buy your Epoxy resin from
By CharlieRam in forum Marketplace DiscussionReplies: 17Last Post: 05-04-2018, 10:18 PM -
Construction Idea Discussion: Large Steel tubes + non shrink grout = win?
By Noplace in forum Machine DiscussionReplies: 1Last Post: 31-05-2016, 12:37 PM -
Sand and Resin Filling Box Section
By grain_r in forum Gantry/Router Machines & BuildingReplies: 6Last Post: 16-12-2015, 08:45 PM
