Thread: Resin vs grout
    Lives in Marple Stockport, United Kingdom. Last Activity: 18 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,347. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by Ninjabika View Post
    Hi
    It is shrinkage compensated, we use it for levelling machines and structures and certain bearings, it's used in a slightly different way, we install and level using jacking bolts, once level a box is built around each foot/ mount which is above floor level, the grout is then poured into the form work until it rises to just above the underside of the mount and left to set, works in that application
    Yes I agree with that but you are levelling the machine first and then applying the grout to the void.
    With epoxy you put a moat around the box section frame with a bridge between to two rails and pour the epoxy and then let it self level in order to get both rails on the same plane.
    But it would be interesting for you to try it for the benefit of others
  1. Self levelling epoxy resin
    By flanagaj in forum Gantry/Router Machines & Building
    Last Post: 21-11-2020, 01:47 AM
  2. Where do you buy your Epoxy resin from
    By CharlieRam in forum Marketplace Discussion
    Last Post: 05-04-2018, 10:18 PM
  3. Replies: 1
    Last Post: 31-05-2016, 12:37 PM
  4. Sand and Resin Filling Box Section
    By grain_r in forum Gantry/Router Machines & Building
    Last Post: 16-12-2015, 08:45 PM
