26-06-2018 #5
Really? Are you sure that ran?
And the reason you didn't post the MasterCam code you were talking about would be.....?
If behaviour differs with code from different CAM packages that strongly suggests your issue is code, not controller or it's settings, most of which are not on the General Config tab.Last edited by magicniner; 26-06-2018 at 08:42 AM.
HSM Advisor - High Speed Machining feed & speed calculator
By magicniner in forum CAD & CAM SoftwareReplies: 2Last Post: 20-01-2014, 12:57 PM -
Speed control
By Saracen in forum Spindles & Drive MotorsReplies: 2Last Post: 29-12-2012, 02:18 PM -
Adjusting speed with vfd
By motoxy in forum Spindles & Drive MotorsReplies: 8Last Post: 24-09-2012, 04:07 PM -
Top speed failing after a bit
By Robin Hewitt in forum Machine DiscussionReplies: 6Last Post: 12-11-2011, 12:46 PM -
Speed and Feeds
By m.marino in forum Tool & Tooling TechnologyReplies: 0Last Post: 08-02-2011, 05:58 PM
