Thread: 6040 y axis
    RichR's Avatar
    Lives in Sunderland, United Kingdom. Last Activity: 2 Weeks Ago Has been a member for 8-9 years. Has a total post count of 8.
    Hi
    Just finished installing the stepper motors to my 6040 and noticed it takes a lot more effort to turn the y axis by hand than the x and z axis.Is this normal behaviour?It seems that motor is going to be under a lot of stress
    Rich
    Quote Originally Posted by RichR View Post
    Hi
    Rich
    First welcome to the forum Rich.
    Can you supply some more info ie does it have ball screws or lead screws, what are you calling the Y axis (is that the long axis or the gantry)
    Can you move the axis freely without the motor attached. A lot of those type of machines need squaring up to make them run smooth. Pictures would help.
    RichR's Avatar
    Thanks for the welcome clive
    Yes I actually meant the Z axis.
    Well i've just got mach3 set up and all 3 motors are working fine and not getting hot under load
    Now the fun begins!
    Hi,there guys I need help with my crap USB- Cnc6040T 3 axis machine, I have the same problem Y axis by hand is hard and motors are not moving it either ?
    I have the one with Black Box /the ballscrew are 1605 type and SFU1605 Ballnut::
    Please help me run thourgh the whole machine fixes ??????:(
    RichR's Avatar
    The reason mine was hard to turn was that I'd installed it wrong.Screws too tight
    That would typically indicate to me that something is misaligned if it becomes hard to turn when the screws are tight - releasing the screws just allows things to move into a more neutral position.
    +1
    If tightening screws causes an issue something is out of alignment.
  1. New 6040 owner looking for advice from others with a chinese 6040/3040
    By itsmillertime in forum Machine Discussion
    Last Post: 14-10-2019, 08:30 AM
  2. 6040 x-axis movement and cutting erratically
    By Roy in forum Chinese Machines
    Last Post: 19-11-2017, 08:51 PM
  3. Chinese 6040 from uk eBay seller x axis problem
    By CommanderKenyon in forum Gantry/Router Machines & Building
    Last Post: 20-02-2015, 02:13 AM
  4. Durability of a 6040 ?
    By jimbo_cnc in forum Machine Discussion
    Last Post: 11-08-2014, 01:37 AM
  5. 6040 router
    By John S in forum Milling Machines, Builds & Conversions
    Last Post: 01-10-2012, 07:18 PM
