    I've never had much luck with the "pause and resume" thing in Mach. It tends to do sporadic and sometimes unpredictable resumes. So now I no longer use it, and do the same as the guy above.
    All the best,
    Dan
    What version are you using?
    Version R3.043.062 is one of the last good, stable versions before The Incompetent New Guys started buggering about with Mach3, creating more problems than they solved in the process.
    Lives in East Lothian, United Kingdom. Last Activity: 2 Days Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    Shouldn't you be using Run From Here, to resume after jogging away from the pause point?
    Pause and resume will do what it says. Resume motion from wherever you've jogged to, even if that means ploughing straight through the work piece to get to the next coordinate, whereas Run From Here should do an initial move then plunge to the resume point, which you should be asked the details of to confirm the initial move is suitable.
    thats correct. it was because i didnt use the run from here option in mach3.
    this video helped me out. https://www.youtube.com/watch?v=x6gv...30738373353584
    the amount of times i have made this mistake lol.
    3.043.066 I think
    I wasn’t aware much had broken in those few versions; do you know what changed?
    Quote Originally Posted by danielbriggs View Post
    3.043.066 I think
    The man who conceived, created and maintained Mach3 sold the company to a bunch of utter Muppets, unless you need support for a plugin that's only in a later version the consensus from far more experienced users than I is don't touch them with a long stick.
    All the best,
    Dan
    I do exactly the same, been caught out with ruined work pieces too many times.
    Quote Originally Posted by needleworks View Post
    wouldn't be as bad if materials were cheap lol. Ive wasted 2 sheets of 12mm cast acrylic at 12 pound each already
    All this nonsense is why I decided to try uccnc about 18 months ago and I haven't looked back. Mach is a buggy piece of crap that has cost me a lot in time, cutters and materials. I can't believe it is still as popular as it is given that there are 2 or 3 alternatives out there now that blow it out of the water.
    I can't tell you how nice it is to be able to stop or pause a program and be sure that it will start again from exactly where you left off (and all without plowing a furrow, breaking a cutter or trying to start a fire!). Mach often used to lose position if it was stopped or paused and I used to rehome, re-zero and air cut, just to be sure, after any uncoded stop.
    With uccnc I can even switch the machine off and shut the pc off for the night in the middle of a long 3d job and carry straight on from the last line the next day (Choc the Z axis before switching off!).
    Uccnc is also well supported, has continuous development and has an excellent forum.
  10. The Following 2 Users Say Thank You to iain1mm For This Useful Post:
  11. #10
    Quote Originally Posted by iain1mm View Post
    I have considered uccnc. Does it have good zeroing functionality. The scripts I use on mach3 2010 screen set have been fantastic.
    Sounds like from your experiences uccnc saves money in the long run
    Sent from my SM-N910F using Tapatalk
  1. Zero Postion Pointer are your steppers returning to zero every time
    By Kev2960 in forum Metalwork Project Showcase
    Last Post: 08-10-2017, 05:33 PM
  2. Mach3 Tool Change Position
    By Mad Professor in forum Artsoft Mach (3 & 4)
    Last Post: 15-07-2013, 06:54 PM
  3. machine cutting sequence, keeps returning to the original point
    By luke11cnc in forum Machine Discussion
    Last Post: 06-07-2013, 04:48 AM
  4. Position feedback
    By D.C. in forum Electronic Project Building
    Last Post: 17-10-2012, 11:30 AM
  5. NEW MEMBER: Returning
    By Leadhead in forum New Member Introductions
    Last Post: 14-08-2011, 09:40 AM
