    There's a European supplier who will supply their machines already fitted with ballscrews (and I think steppers/servos), but I can't remember their name.
    IIRC they were based in Austria, but it's been a few years since I looked at their website.
    How do they work manually, given the question to be addressed -
    Quote Originally Posted by IanT View Post
    I am in the process of choosing a milling machine for hobby use.
    Mainly milling aluminium, and occasional mild steel.
    I intend to convert it to CNC in the future.
    Wabeco, maybe? I think they list a "CNC-ready" vertical mill already fitted with ballscrews.
    I'm buying an AMAT25LV from Amadeal when they come in stock.
    Was going for the 30LV but can't fit it in yet and the extra rpm on the 25 will suit better. Will replace my X2.
    Converting it with ballscrews and steppers 23/34 size to run off Mach3.
    If all goes well I will move the Seig X2 conversion and use it primarily for drilling. Then in a year or so replace the X2 with the 25LV and buy a 30 to put in it's place. Might try to sell the X2 if I can bring myself to part with it.
    Could do with a lathe really, I want to make new pulleys to bump up the rpm's on both AMAT's. Got a few plans and need a re-jig in the cave.
    Keep me out of trouble for a couple of years I suppose :D
    If I didn't mind gear noise I'd have got a Warco WM18 by now but being where I am I need as quiet as possible.
    Quote Originally Posted by Cube3 View Post
    Hi Ian,
    I am currently converting a Warco GH universal. I have it all in CAD and would be happy to explain how and what I have done so far.
    Regards Simon
    Sent from my SM-G925F using Tapatalk
    . Hi, I am thinking of converting a warco super major, and would be interested in knowing your plans for your conversion. My mill as power on the z axis and x axis, and wonder if I can keep these lead screws in the conversion. Would be glad to hear your views on this. Michael
  5. Hi Michael,
    If these are the lead screws that came with the machine then I would suggest that they are not suitable due the backlash. You would have to check to see if they are a buttress style thread, if so then you to change for ballscrews. The Super Major looks the same as my mill so I can provide some guidance and explain how I converted mine.
    I have converted mine to a 3 phase motor and VFD, kept the gearbox and can get 3000rpm which help with the smaller cutters. I could get more rpm but I don't want to explode the gearbox!
    Do you use CAD, if so what CAD system?
    Regards
    Simon
  6. #16
    Hi, thanks for getting back, yes I do use cad. Solidworks for drawings, fusion 360 or vcurve for g code and mach3 for the machine. I have a large cnc router that I use, but the z axis is very limited so the reason I have the warco. I would be interested in knowing which ball screws you used, what sizes etc, motors you used, in fact all the details. Michael
  7. Hi Terry,
    Send an email to simon.m at cubethree.co.uk and I'll send over my CAD in SW2018. I'll also dig out some images of the machining of the casting for the leadscrews.
  8. I used a Bridgeport to machine all in one go the ballscrew mounting features. Used a 90 head to do the end faces. Although a slightly more complicated setup it got everything square and true as best I could.
ID:	27619Click image for larger version.
  9. #19
    I converted my Sieg 2.7 to CNC and I am happy with it.
    What can I say, it's Chinese, so you will need to adjust and improve a couple of things here and there, but nothing major, or difficult. I had to grind a bit of the underside of the table to be able to fit the ballscrew, but other than that it was a straight forward conversion. I read this forum extensively to get me acquainted with what drives to get, steppers, etc. and eventually I made my own toroidal PSU as per instructions in this helpful forum.
    Don't expect super fast speeds or large widths of cut, it's a small mill after all, but if you are sensible, you can have a nice machine that you will enjoy.
    The main negative is that the head is fixed, i'e, it doen't swivel or tilt forward or backward, so for tramming you need to shim the base of the column which requires a little more patience, but quite doable. If you were to get this mill, get the version with the longer table.
  10. #20
    I've only just finished my AMAT25. Hopefully start testing it out this week, time permitting.
  1. NEW MEMBER: Milling machine conversion
    By Pmw71 in forum New Member Introductions
    Last Post: 30-05-2020, 01:03 PM
  2. CONVERSION: Clarke milling machine CNC conversion CMD1225D
    By Jonathan in forum Conversion Build Logs
    Last Post: 06-02-2019, 01:18 PM
  3. CONVERSION: Chester 626 milling machine conversion.
    By RobWilson in forum Conversion Build Logs
    Last Post: 23-04-2018, 08:14 AM
  4. CNC Build - TEP milling machine conversion
    By craynerd in forum Gantry/Router Machines & Building
    Last Post: 06-07-2015, 02:09 AM
  5. Axminster RF31 Milling Machine CNC conversion
    By 1113562 in forum Milling Machines, Builds & Conversions
    Last Post: 30-03-2010, 12:42 AM
