    Quote Originally Posted by the great waldo View Post
    Hi Bert
    Do you think it's not worth bothering with the bleed resistor ?
    cheers
    Andrew
    Eh... well when nothing is connected it takes forever and a day to get rid of the lethal voltage levels...
    So.. you can check voltage level vs time after switching off.
    I would say 10 seconds to 10 ish volts is fine...
    If it takes more time then what you are comfortable with put a resistor in.
    50VAC 50hz / 120VDC was once considered the critical level for safety under normal conditions.
    I would say all the metal near raises risks a bit.
    So... then the energies stored in the caps is the next thing to worry about.
    Caps discharge at high amp rate on shortcircuit... like a welding torch...
    So big caps are always dangerous.
    The above is just my opinion.
    More safe is always better.
    So never work on live systems, always check your measuring device for good to go before use.
    Then check for 0 voltage and then check your measuring device is still in good working order after that.
    https://youtu.be/EoWMF3VkI6U
    This guy explains it well
    https://youtu.be/sI5Ftm1-jik
    He is more fun though
    Grtz Bert
  1. need help! choosing right kit
    By msacnc in forum Gantry/Router Machines & Building
    Last Post: 17-09-2014, 09:41 AM
  2. Resistor Question
    By GTJim in forum General Electronics
    Last Post: 07-04-2013, 10:01 AM
  3. Resistor Calculator
    Last Post: 17-04-2012, 05:22 AM
  4. ATX power supply - load resistor - do I need one ?
    By rckeith in forum General Electronics
    Last Post: 18-08-2010, 03:21 PM
  5. What type of resistor?
    By Smiler in forum General Electronics
    Last Post: 05-12-2008, 10:04 PM
