11-07-2018 #6
Consensus changes from time to time. Current thinking supports providing equipotential bonding as much as possible and grounding both ends of the screen. (Incidentally, conventional consensus is to ground one end for susceptible cables, and both ends for emissive - the spindle (and steppers) are emissive).
This is about to move the conversation away from your question - I'm guessing that the electrical connections from the controller to the machine are only the spindle supply, stepper drives, and possibly limit switches. In which case, a single fault in the spindle could result in the whole machine presenting a dangerous voltage. This is one reason to ground both ends of the shield, to export an earth to the machine. Better still, provide export the earth via a heavy gauge wire from the controller to the machine - or use a 4-core CY/SY cable - you avoid the risk of earth loops then and you can ground both ends of the screen.
WANTED: Conqueror Design stepper driver or stepper conversion board
By pistolknight in forum Items WantedReplies: 1Last Post: 25-05-2019, 11:57 AM -
Chinese 300W DC spindle - is the spindle shaft grounded?
By HankMcSpank in forum Spindles & Drive MotorsReplies: 44Last Post: 26-11-2016, 07:25 PM -
TB6560 controller Runs spindle on power up When Mach3 plunges spindle stops
By RoyT in forum Spindles & Drive MotorsReplies: 5Last Post: 29-09-2014, 02:42 PM -
How do I wire a stepper driver to a stepper motor?
By swood1 in forum Stepper & Servo MotorsReplies: 7Last Post: 21-09-2014, 05:40 PM -
FOR SALE: Metabo 710W 230V Electric spindle, stepper motors, Tr nuts 20x4
By Vladimir_MD in forum Items For SaleReplies: 3Last Post: 09-04-2010, 05:24 PM
