15-09-2009 #4
Might be worth experimenting with faster speeds for better finish... 160 sounds slow for 12mm stock (what material?).
EDIT re speeds I should read your post fully before opening my gob!
Incidentally if you are machining a fairly long ballscrew or whatever you might want to make sure the back end of it is supported to stop it flailing around - a collar type arrangement to plug into the back of the spindle hole would do it.Last edited by bikepete; 15-09-2009 at 04:28 PM. Reason: missed reading the bit re speed!
taper roller bearings vs deep groove ball bearings
By dsc in forum Linear & Rotary MotionReplies: 8Last Post: 10-03-2014, 08:06 AM -
RFQ: Parts need turning
By ams in forum Projects, Jobs & RequestsReplies: 17Last Post: 15-01-2014, 12:27 AM -
Morse taper drills
By John S in forum Marketplace DiscussionReplies: 7Last Post: 08-05-2013, 07:00 PM -
larger home made milling spindles - NMTB/ R8 taper?
By jonnydeen in forum Tool & Tooling TechnologyReplies: 6Last Post: 13-09-2012, 11:17 AM -
FOR SALE: Clarkson Autolock Collet chuck set, Boxed INT 30 / NMTB30 taper
By swarf-boy in forum Items For SaleReplies: 0Last Post: 04-01-2011, 05:28 PM
