My mk2 and mk3 used aluminium profile to bolt the rails to and I made plenty of good parts with it (including parts for the current mk4 under construction).
I did not flatten the surfaces or prep them and it made a very useable machine.
You can buy pre-machined aluminum profile which will make them very flat but you pay more for it.
19-07-2018 #2
20-07-2018 #3
Aluminium box profile is not a good idea for this purpose. They twist and deform too easy and are not very flat unless special made with very thick walls. Especially once you start drilling holes in the box it will be noticeably worse. If you use aluminium profiles get 45x90 or better. My machine is built based on 45x90 but it is regarded as small, so it's OK for that. I mill aluminium, PCB as well as other, softer material, but my work area is 310 x 270 mm with a 150mm maximum Z. The total weight is about 90kg, excluding the PSU, electronics, wiring and the spindle. The foot print is 750 x 650mm, it is a stand alone type with fixed gantry beam, moving table.
Self levelling epoxy resin
By flanagaj in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 21-11-2020, 01:47 AM -
Use of epoxy for levelling
By Neale in forum Gantry/Router Machines & BuildingReplies: 102Last Post: 25-08-2019, 04:21 PM -
BUILD LOG: 1st Build, Steel, Epoxy 24"x24" for Wood
By wallyblackburn in forum DIY Router Build LogsReplies: 79Last Post: 11-05-2018, 08:45 PM -
By samsagaz in forum Gantry/Router Machines & BuildingReplies: 9Last Post: 07-05-2016, 12:40 AM -
BUILD LOG: Vertical fixed gantry. Design & build. (Steel/epoxy)
By Greeny in forum DIY Router Build LogsReplies: 8Last Post: 19-08-2013, 08:26 PM
