This sounds overcomplicated to me or I don't understand what you are trying to do. Why not just use a simple ordinary motor to do this? The motor shaft should drive the paddle up and down creating the waves. A speed regulator could be used to adjust the speed of the motor. I don't understand why use a stepper and a UC300ETH for this project, or how you plan driving the motor. The UC300ETH requires some software as well, like the Mach3 or UCCNC. With those you can write and run a macro, or run G code in a loop to do it, but it seems very complicated for this simple task.
20-07-2018 #2
A Scotch Yoke with the drive pin mounting point adjustable for radius, a variable speed drive for the motor, tachometer on the shaft of the Scotch Yoke.
That gives you variable amplitude from zero to the size limitation of the Scotch Yoke you build, with variable speeds from zero to things you could only dream of with steppers ;-)You think that's too expensive? You're not a Model Engineer are you? :D
21-07-2018 #3
6040 x-axis movement and cutting erratically
By Roy in forum Chinese MachinesReplies: 1Last Post: 19-11-2017, 08:51 PM -
Arc movement issue
By lukecnc2012 in forum Metalwork DiscussionReplies: 4Last Post: 09-08-2015, 07:15 PM -
G53 movement
By Saracen in forum Programmers CornerReplies: 3Last Post: 05-02-2015, 07:58 PM -
axis movement jamming
By Skydeals in forum Linear & Rotary MotionReplies: 3Last Post: 18-12-2014, 10:27 AM -
Z axis assembly - unsupported rail for very limited movement
By dsc in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 10-10-2012, 12:44 PM
