    Hi Clive,
    Two db25 boards. Interesting! I guess I would need another parallel port card in the PC. I have one of the green cards like this and a blue one as second link so enough between these two.
    Potentially a bit of a head scratcher though eh. Is the software side straightforward, assigning ports and pins etc?
    https://www.ebay.com/itm/CNC-6-Axis-...-/121480961528
    https://www.aliexpress.com/item/Upgr...001497211.html
    ....Update
    Just thinking about it I could use the one of the BOB to run the 3 axis and the slave and the other BOB to run the B/A axis and secondary sensors.
    I'm not that familiar with parallel port/db25 instruction. Can I daisy chain the two boards together or do I need to run a separate card to the second BOB?
    Much food for thought
    Not sure what you mean by this. But to use two PP BOB's you will need to P ports on the pc. so you would need another PP card fitted and the two cables one to each BOB.
    I have been using Linuxcnc for these simple jobs but it is a learning curve. I think Mach3 can take at least two PP BOB's then you would set them up in ports & pins. Plenty of vids on the net for that.
    Cheers Clive!
    Yeh i've just been reading up on the setting up Mach3 with two PP ports. Think its a case of getting lucky if you dont get a driver conflict on the installed PP card however it'll resolve what I want. I have the boards so might as well give it a go :)
  1. Alloy 5083 Tooling plate Suitable for gantry build?
    By PaisleyPCdoctor in forum Gantry/Router Machines & Building
    Last Post: 20-01-2018, 07:05 PM
  2. NEW MEMBER: Can anyone recommend a suitable machine / build log?
    By Geoff.k in forum New Member Introductions
    Last Post: 28-03-2017, 11:03 PM
  3. BUILD LOG: New build - Steel - 3 Axis initially then conversion to 4 axis.
    By Slixxor in forum DIY Router Build Logs
    Last Post: 29-12-2016, 02:57 AM
  4. FOR SALE: head stock with chuck for 4th axis slant bed etc
    By dazza in forum Items For Sale
    Last Post: 10-03-2015, 02:03 PM
  5. PWM Fan control, is this suitable?
    By Smiler in forum General Electronics
    Last Post: 25-03-2009, 02:52 PM
