    I'm not that familiar with parallel port/db25 instruction. Can I daisy chain the two boards together or do I need to run a separate card to the second BOB?
    Not sure what you mean by this. But to use two PP BOB's you will need to P ports on the pc. so you would need another PP card fitted and the two cables one to each BOB.
    I have been using Linuxcnc for these simple jobs but it is a learning curve. I think Mach3 can take at least two PP BOB's then you would set them up in ports & pins. Plenty of vids on the net for that.
  2. The Following User Says Thank You to Clive S For This Useful Post:
  3. #2
    Cheers Clive!
    Yeh i've just been reading up on the setting up Mach3 with two PP ports. Think its a case of getting lucky if you dont get a driver conflict on the installed PP card however it'll resolve what I want. I have the boards so might as well give it a go :)
  1. Alloy 5083 Tooling plate Suitable for gantry build?
    By PaisleyPCdoctor in forum Gantry/Router Machines & Building
    Last Post: 20-01-2018, 07:05 PM
  2. NEW MEMBER: Can anyone recommend a suitable machine / build log?
    By Geoff.k in forum New Member Introductions
    Last Post: 28-03-2017, 11:03 PM
  3. BUILD LOG: New build - Steel - 3 Axis initially then conversion to 4 axis.
    By Slixxor in forum DIY Router Build Logs
    Last Post: 29-12-2016, 02:57 AM
  4. FOR SALE: head stock with chuck for 4th axis slant bed etc
    By dazza in forum Items For Sale
    Last Post: 10-03-2015, 02:03 PM
  5. PWM Fan control, is this suitable?
    By Smiler in forum General Electronics
    Last Post: 25-03-2009, 02:52 PM
