  1. your using kmotion on yours arent you?
    how did you do spindle alignment for atc? in kmotion or in the servo?
    that was one thing that drove me nuts trying to work it all out.
    Lives in East Lothian, United Kingdom. Last Activity: 1 Hour Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,990. Received thanks 374 times, giving thanks to others 9 times.
    Yes, I'm using KMotion.
    I never bothered with alignment, as my machine is a later one without the locating dogs.
    I do have the spindle servo index pulse connected to the KFlop, so if I did want to implement alignment, it would only involve a couple extra lines of code to rotate the spindle to the required position.
    i went to southern engineering 2017 and spoke to some of the stalls selling tool holders, two did say they still had the moulds for bt35, but the demand just wasnt there
  4. The Following User Says Thank You to andy_con For This Useful Post:
  5. was just wondering - anyone think it would be possible to machine a conversion sleeve to go in the spindle- bt35 to iso30?
    iso 30 collet chucks are rediculously cheap now . i have around 150 for my routers!
    if i can find the exact dimensions i might get one of the chinese engineering companies that keep saying how good they are to knock up 10. thoughts?
  6. #5
    It would probably be easier, and far more reliable, to just buy a new spindle from Denford.
    IIRC they're still using the same spindle in their new machines, so it would just be a case of swapping the main spindle, along with any other bits that differ. Then of course you have the problem of converting the ATC.
    I'm sure a post on the denford forum would give a definitive answer.
  7. #6
    I have a full cad design to turn a standard 6 station ATC disk into an 8 or 10 station disk
  8. #7
    Quote Originally Posted by andy_con View Post
    Isn't the 8 tool disc CAD available on the denford forum?
    It's certainly not as big a problem as the spindle.
  1. FOR SALE: Denford Triac PC inc Denford table plus chucks, and Denford CD software etc
    By Piero franchi in forum Items For Sale
    Last Post: 14-02-2017, 04:47 PM
  2. FOR SALE: Denford Triac + Denford Orac + other stuff
    By Clive S in forum Items For Sale
    Last Post: 06-02-2017, 11:47 PM
  3. collet ID for denford router porter cable spindle
    By kell in forum Porter Cable Routers
    Last Post: 19-12-2015, 01:52 PM
  4. Gloster 5c collet chucks
    By dazza in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 28-01-2015, 04:25 PM
  5. WANTED: ER20/25 straight shank collet chucks
    By m_c in forum Items Wanted
    Last Post: 24-10-2011, 12:19 PM
