Thanks for your comments.
I did that because the further I move them apart, the less z height I have, because I have only 300mm rails for the Z axis.
Here is the machine at the moment. The z axis is at the lowest point of its travel. I've modelled the ballscrews and rails etc exactly as they are. They arrived a few days ago. Still waiting for the second ballscrew for the x axis.
My only problem was trying to keep the z axis as close to the Y as possible, so that there is less overhang or twist forward on the gantry. So I had to move the ballscrew to the back of the gantry. Not ideal, but with everything being 16mm and 20mm alu plate, I figured it wouldn't pose too much of a problem. Thoughts?
I have now sourced 80x80x5mm steel box section, and I got it through a friend at work for £76 for a 7.5m length. Not too bad!
I've also ordered a 2.2kw water cooled spindle, 425oz motors and drivers. I'll be buying the transformers and caps soon for the power supply. Any idea what control board I should use?
Note I haven't modelled the second ballscrew for the x axis. Its basically a copy of the right hand side one.
Please let me know your thoughts?
Neal
Aluminium Extrusion Router Build
By NFryer in forum Gantry/Router Machines & BuildingReplies: 76Last Post: 03-07-2019, 07:59 PM -
Homemade CNC with Scrap + Chinese parts || Objective: Milling Aluminium ||
By laranjas3 in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 16-11-2017, 10:18 PM -
FOR SALE: Aluminium Extrusion
By vigen20 in forum Items For SaleReplies: 2Last Post: 24-07-2012, 11:01 PM -
BUILD LOG: Aluminium Extrusion CNC Router Build
By joshendy in forum DIY Router Build LogsReplies: 9Last Post: 10-04-2012, 08:26 PM -
BUILD LOG: Work scrap bin router build
By Vic66 in forum DIY Router Build LogsReplies: 32Last Post: 17-01-2010, 08:51 PM
