    Quote Originally Posted by Silver View Post
    I am aware that we can't do away with the conversion process but that can be done on a board directly rather than having the UC100 plugged in can't it?
    What o am saying is that even with the UC100 I will still have the same control system. It's only a thee axis and that alone hampers development.
    I was planning to upgrade it eventually to 4 axis but with the issues of the converter it's possibly brought that forward as I still see that the UC100 is a "fix" and an adaptor rather than buying a replacement controller that doesn't need need the UC100.
    Are you a CNC drive Sales man or ambassador at all? Seem to be pushing their products.!!
    No I have no relation to the company other than I am a user. Have a UC300USB and a UC300ETH. That's all. Have used a Chinese USB motion controller before which was not a UC100 fake, it worked well unless I wanted to use the vacuum cleaner at the same time or wanted to use probing. I have no interest in selling CNC Drive products but I am also not recommending anything I don't have experience with.
    You mentioned Mach3 and USB. I have no idea about any other solution which is financially and functionaly better. Nevertheless if you want to use W10 and the blue card is working then buying a UC100 is really a no brainer, you just replace the fake one with it.
    If you want to use a stand alone controller then you don't need it.
    But you do as you want. I really don't care. Just wanted to help.
    Thank you, it was a misunderstanding on my behalf as I understood from your comments that I would need the motion controller UC100 no matter what I upgraded with.
    That's what I couldn't understand.. But I do now..
    Thankyou and now fully understand what's needed, it's purely me not wanting to invest in something just to get me going when I could upgrade it..
    I have now installed the old PC and got it running through the PP for now..
    Thanks for everyone's input and guidance of what the issues are and finally getting to the bottom of it as I didn't understand about the UC100 issue.
    I will be surfing the forums for the upgrades solutions going forward..
    Thanks again everyone..
    If it runs well through the PP and you are happy with it then just leave it as it is for now, until you know what you need. In my opinion the UC400ETH would be a better upgrade than the UC100, but again that's just my opinion.
    You don't "need" the UC100, but you MUST have a motion controller if you plan to use W10 or W7 64 bits. The PP is not supported by Microsoft after W7 32 bits.
  1. Replies: 8
    Last Post: 20-02-2019, 11:40 AM
  2. XHC WHB03 mpg pendant Mach3 Driver
    By Noplace in forum Artsoft Mach (3 & 4)
    Last Post: 07-12-2015, 06:43 PM
  3. Replies: 0
    Last Post: 03-01-2015, 03:40 PM
  4. Driver wiring to my computer for mach3 to control
    By AdCNC in forum Motor Drivers & Controllers
    Last Post: 01-04-2010, 12:27 AM
  5. Mach3 / Laptop No line driver !
    By bruce_miranda in forum Artsoft Mach (3 & 4)
    Last Post: 11-09-2008, 05:42 PM
