Thread: Mach3 Lathe Threading Struggles
03-08-2018 #11
What should happen with Mach3 threading, is the tool moves to the start point, it then waits for the spindle speed to stabilise, and then the threading move should synchronise with the spindle pulse.
However I did just remember, if Mach calculates that the axes can't respond quick enough to the spindle speed for the given move, then motion will just hang. It could be worth dropping the spindle speed down a good bit, and re-running the code.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
Orac lathe to Mach3 conversion advice/direction please
By Hunter in forum Lathes, Lathe Rebuilding & ConversionsReplies: 1Last Post: 18-08-2014, 09:36 PM -
Threading plastic / inserts
By jimbo_cnc in forum General DiscussionReplies: 7Last Post: 11-08-2014, 11:52 AM -
WANTED: Boxford Threading Dial
By Raymond in forum Items WantedReplies: 5Last Post: 07-06-2014, 01:37 PM -
threading ground bar ends
By dazza in forum Metalwork DiscussionReplies: 39Last Post: 11-02-2014, 11:41 PM -
NEW MEMBER: New with a threading problem
By GeoffS in forum New Member IntroductionsReplies: 4Last Post: 02-12-2009, 09:23 PM
