    Okay, it's been a while, and this project was put to a side but now I'm back at it. I bought a cheap USB motion controller from eBay
    https://rover.ebay.com/rover/0/0/0?m...2F163110531211
    I plugged it in to my laptop for testing, connected some relays and they work okay, however I don't get any rpm readout! The index light comes on in the diagnostic screen but no matter what I do, the sTrue stays at 0 🤔
    Is the controller supposed to tell mach3 what the rpm is?
    Did I go wrong by going cheap?
    Help!
  2. you need a controller that will support threading in the controller. this cannot be done in software.
    the index signal must be interupt driven- so its very fast.
    software will always lag so you will never get the same start point for threading.
    you also require spindle encoder - which can be 2 sensors 60 degrees apart
    threading- and cheap- are never going to work
    Quote Originally Posted by mondrota View Post
    Hmm, not narrowing the angle there! ;-)
    Lives in East Lothian, United Kingdom. Last Activity: 1 Day Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    From the top of head in no particular order, the following support turn/single point threading-
    Pokeys
    PMDX
    KFlop
    CS-Labs (although I think you may need the higher end controller with an MPG module, and not the cheaper controller)
    Centroid
    IIRC Pokeys (and possibly PMDX) will work with a basic single/multislot sensor, whereas the rest require a proper quadrature output encoder.
    Does anyone do a good Stand Alone Controller for lathes?
    When I was looking at the Chinese standalone controllers, I'm sure some were available in turn versions.
  1. Orac lathe to Mach3 conversion advice/direction please
    By Hunter in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 18-08-2014, 09:36 PM
  2. Threading plastic / inserts
    By jimbo_cnc in forum General Discussion
    Last Post: 11-08-2014, 11:52 AM
  3. WANTED: Boxford Threading Dial
    By Raymond in forum Items Wanted
    Last Post: 07-06-2014, 01:37 PM
  4. threading ground bar ends
    By dazza in forum Metalwork Discussion
    Last Post: 11-02-2014, 11:41 PM
  5. NEW MEMBER: New with a threading problem
    By GeoffS in forum New Member Introductions
    Last Post: 02-12-2009, 09:23 PM
