Page 2 of 2 FirstFirst 12
    hi efstathios greece
    to run my 2.2kw water spindle as part of a new machine build. start stop,it worked very well and if possible also set the speed from Mach3 gcode. Its not clear to me from the wiring diagrams of the VFD which.
    I used parameters/settings for the XSY-AT1 VFD, George (tarawa)
    Machifit NVCM /6 Axis CNC Controller MACH3 USB
    Minleaf AT1-2200X 2.2KW 220V PWM Control Inverter 1Phase Input 3Phase Out Inverter Variable Frequency InverterClick image for larger version.
    Hi can some1 help me setting my inverter? the acceleration and speed ect. for my plastering machine plssss
    https://youtu.be/DyEAEZMtDQw?t=11
    Buongiorno ragazzi..mi trovo davanti ad un problema per me abbastanza grosso..premetto che di inverter non ci capisco nulla.
    Ho acquistato questo inverter XSY-AT1..e devo configurare con il mio tornio DamatoMacchine.il suo motore è un 220V x 750w 50Hz cioè monofase e la corrente di casa e 220v...ho provato spulciando in rete ma non ha portato nessun risultato..chi mi può dare l'esatta sequenze di impostazioni.con manuali.in anticipo grazie.
    // TRANSLATION // Lee
    Hello guys .. I am faced with a problem that is quite big for me .. I presume that I do not understand anything about the inverter. I purchased this XSY-AT1 inverter .. and I have to configure it with my DamatoMacchine lathe. Its motor is a 220V x 750w 50Hz that is single-phase and the house current is 220v ... I tried sifting through the network but it didn't bring any results ..who can give me the exact sequences of settings. with manuals. in advance thanks.
    Quote Originally Posted by Luciano View Post
    Is this what you are looking for https://www.youtube.com/watch?v=uMTb7uy1HfU
  5. The Following 2 Users Say Thank You to Clive S For This Useful Post:
  6. #15
    alguien sabe como emplear la comunicacion rs 485 de este modelo de variadores .y el lenguaje que se emplea si es hexdecimal binario etc.....un saludo
    Translation by Lee
    "someone knows how to use the rs 485 communication of this model of drives. and the language that is used if it is hexdecimal binary etc ..... a greeting"
  7. #16
    Quote Originally Posted by maxivariador View Post
    Folks, for posterity (and hoping someone can help), here's some info on getting through to XSY-AT* VFD using Modbus ASCII protocol: https://www.chipmaker.ru/topic/21809...omment=4791765
    I've written a little python program, but so far I've got only random garbage back (padded with lots of zeros) from the serial port, regardless of what command I send and baud rate used. The VFD works fine using panel controls.
    Code:
    # send the "jog" command
    # ./send-cmd.py '3A 30 31 30 36 32 30 30 30 30 30 30 33 44 36 0D 0A'
    ascii: 3A 30 31 30 36 32 30 30 30 30 30 30 33 44 36 0D 0A hex: bytearray(b':010620000003D6\r\n')
    response: [192, 236, 214, 246, 54, 182, 246, 246, 246, 246, 246, 246, 150, 118, 77, 229, 235]
    Hope someone has figured it out and can help..
  1. Milling styrofoam board enquiry
    By marbles in forum General Discussion
    Last Post: 13-06-2017, 09:26 PM
  2. Wiring a Bandsaw to VFD ? Speed?
    By Boyan Silyavski in forum Motor Drivers & Controllers
    Last Post: 18-08-2016, 11:53 AM
  3. A right balls up with CJ variable speed control drive wiring
    By suesi34e in forum General Electronics
    Last Post: 30-06-2016, 09:32 PM
  4. TD torch cut height enquiry
    By marbles in forum Plasma Table Machines
    Last Post: 19-02-2016, 11:57 AM
  5. RFQ: Early enquiry
    By boldford in forum Projects, Jobs & Requests
    Last Post: 30-07-2012, 06:40 PM
