Thread: Advice for cutting acrylic sheet
I cut 3mm acrylic with a 1.5mm single flute spiral, using double faced tape.
Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
03-08-2018 #2
I use single flute spiral EM with lots of air for cooling & chip removal, facing cuts give me parts which flame polish (Very carefully) to a good level of transparency.
07-08-2018 #3
thanks for all your replies. I think i'll try a single flute cutter with my vacuum table, failing that i'll move on to the double sided tape and if that fails i'll crack out the superglue.
Many thanks for your suggestions, it's appreciated, i'll post how I get on.
Cheers.
09-08-2018 #4
If you want to cut through acryllic then you want the cheap Chinese K40 laser. A 40W laser converts acrylic to vapour, it simply disappears at an amazing rate of cut. To glue acrylic you need chloroform. I bought a litre from Italy on eBay, it may not be so easy to get once we leave the European free trade thingy so get some while you can.
09-08-2018 #5
09-08-2018 #6
Chloroform dissolves acryllic for that perfect glue line. Everything else is but a poor sustitute.
09-08-2018 #7
https://uk.rs-online.com/web/p/produ...E&gclsrc=aw.ds
Methylene chloride can also be used to bond the stuff, but it will mar the surface if you use too much.Last edited by cropwell; 09-08-2018 at 11:38 AM.
09-08-2018 #8
Chloroform is trichloromethane.
09-08-2018 #9
Advice for cutting sheet aluminium
By Drucook in forum Metalwork DiscussionReplies: 6Last Post: 13-06-2018, 03:19 PM -
Which cutting tool on acrylic?
By piper1 in forum Machine DiscussionReplies: 7Last Post: 06-07-2017, 11:12 PM -
CNC cutting service (acrylic/perspex, mdf, plywood, carbon etc)
By adrpak in forum Manufacturer NewsReplies: 0Last Post: 28-04-2017, 06:38 AM -
Acrylic Cutting Help
By Tenson in forum Machine DiscussionReplies: 26Last Post: 08-11-2016, 08:15 PM -
Laser cutting 10mm acrylic?
By camhguh in forum Laser Machines & BuildingReplies: 14Last Post: 04-09-2012, 12:51 AM
