    Chaz's Avatar
    Quote Originally Posted by AndyGuid View Post
    Was just trawling through some older "subscriptions" and think this might be your "reference box" Chaz :
    From http://www.mycncuk.com/threads/10480...growing-nicely
    Yep.
    Nick's Avatar
    Lives in East Yorkshire, United Kingdom. Last Activity: 06-01-2021 Has been a member for 8-9 years. Has a total post count of 26. Received thanks 2 times, giving thanks to others 0 times.
    Chaz, that might work, how much does it weigh? I am based in Yorkshire, where about are you based?
    Just changed jobs, making very slow progress on the build at the moment.
    Chaz's Avatar
    Quote Originally Posted by Nick View Post
    Hi, its fairly heavy (estimated 300-400kg). Pity you arent closer, I'm in Uxbridge / Ickenham, West London, Near the M40 / M25.
    Sure, happy to help if I can.
    Nick's Avatar
    This is a bit delayed but I owe a big thanks to Chaz who has let me borrow his reference surface. It has been really helpful and I am not sure how I would of progressed without it. I tried to pick it up in a Fiesta, which unsurprisingly didn't work, thankfully it came on a pallet.
    I've been making slow progress, I settled for an angle grinder for the cutting of the cast iron blocks, it took forever... I have managed to rough scrape all the surfaces for the column.
    These blocks of cast iron are the ones highlighted below.
    I have also scraped the main cast iron block.
    They're not perfect but within 0.03 mm. I am making the mold and getting the inserts ready, I plan to cast the column next week. Just trying to work out how to drill 18mm holes through the 2 inch cast iron blocks, my drill press isn't up to it and I really don't want to have to buy a mag drill, I don't know if anyone has any other ideas?
    Nick
    Chaz's Avatar
    Nick
    Scrape Scrape Scrape ....
    I was going to ask how you were getting on.
    Would the blocks fit on a lathe cross slide to drill the holes using a bit or boring head in the chuck?
    Or the other way around with the block rotating on a lathe face place and bit or boring head in the tailstock?
    Nick's Avatar
    Quick update
    That was a great idea with the lathe cross slide although I couldn't quite get it to work, having issues with its size. I ended up getting a mag drill... Drilled 60 holes and tapped for the insert bolts.
    Mould made and epoxy poured, all 150kg of it. Got it done in about 90 minutes with two of us. Had some slight issues, no vibration, we ran out of pigment towards the end and the mould blew out on one side. But overall went ok, if anyone wants more details on how to go about this I could write a more detailed post / video.
    Will probably de-mould tomorrow.
  1. Where to start? Vertical Mill CNC conversion.
    By Richard in forum Milling Machines, Builds & Conversions
    Last Post: 26-09-2021, 03:11 PM
  2. WANTED: Harrison mill Vertical head
    By D-man in forum Items Wanted
    Last Post: 18-06-2016, 01:43 PM
  3. Epoxy granite or mineral casting
    By mike mcdermid in forum Gantry/Router Machines & Building
    Last Post: 20-02-2014, 06:21 PM
  4. Epoxy Granite Molds?
    By gavztheouch in forum Moulding Machines
    Last Post: 18-02-2014, 07:28 PM
  5. BUILD LOG: Vertical fixed gantry. Design & build. (Steel/epoxy)
