21-04-2020 #25
Spindle - 2.2Kw, i'm using a mist cooler, pressurised coolant and air adjusted to make a large droplet mist. Aluminium all 6082
So it sounds like i'm doing a few things right but a lot wrong, i'm using adaptive tool paths in fusion.
The best success i've had is with 8mm 3 flute carbide end mill - 12000 RPM, feed 2.5 - 3m/min, DOC 5mm, WOC 20% this worked really well for a while but eventually it looked like it engaged a bit to much and stalled and broke.
I managed to break a 10mm end mill, similar settings, stalled really quickly (with hindsight i'm not sure why I did this). I've been using an aliexpress 12mm HSS rougher with good success recently with much smaller DOC to reduce load.
I've broken all my 3 flute 5mm /6mm end mills so far, best success was 16000 RPM, feed 1.2m/min, WOC 20%, DOC 2mm 0.025 feed per tooth.
I think your right with the rubbing, the chips didn't look very big with the 5/6mm cutters, i'm a bit concerned if I increase the RPM to 20-24k I would need to go at crazy feed rates? it looks scary going higher than 1m/min with a 5mm. What sort of feeds are you using at 24k RPM?
I could double the 5mm feed per tooth to 0.05, that would give 3m/min with 20k RPM? I could increase the RPM on the 8mm 3 flute: 16K RPM, 3.2m/min feed and reduce DOC?
Where to start? Vertical Mill CNC conversion.
By Richard in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 26-09-2021, 03:11 PM -
WANTED: Harrison mill Vertical head
By D-man in forum Items WantedReplies: 0Last Post: 18-06-2016, 01:43 PM -
Epoxy granite or mineral casting
By mike mcdermid in forum Gantry/Router Machines & BuildingReplies: 46Last Post: 20-02-2014, 06:21 PM -
Epoxy Granite Molds?
By gavztheouch in forum Moulding MachinesReplies: 8Last Post: 18-02-2014, 07:28 PM -
BUILD LOG: Vertical fixed gantry. Design & build. (Steel/epoxy)
By Greeny in forum DIY Router Build LogsReplies: 8Last Post: 19-08-2013, 08:26 PM
