    Lives in East Lothian, United Kingdom. Last Activity: 10 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,970. Received thanks 369 times, giving thanks to others 9 times.
    For the next part of the Roland retrofit puzzle, I'm looking for some low current stepper drivers.
    I had thought about some TB6xxx's given their low cost, but I'd like something with a bit more current adjustability, as I'm not sure what current I'll need, and the 0.5A jump in settings seem a bit high.
    The original chips are TEA3718, which have a maximum current of 1.5A, but I'd guess are being pushed no where near that hard. Unfortunetly I can't seem to work out what current they're set to use, as the datasheet doesn't list any clear cut formula, and the final current is a result of motor feedback and resistors.
    I've had a look at the 3D printer options, and although things like the Polulu and DRV8825 stuff ticks the boxes in terms of voltage/current adjustability, they're all DIP mount.
    Any other cheap options to consider, or are some TB6600's and hoping 0.5A is good enough the most convenient option?
    Go for the DIP mount drivers and use a section of strip board?
    You can add your own screw terminals.
    I'm thinking that may be the best option, and the project may be creeping towards a custom PCB to mount everything neatly.
    Unregulated 36V PSU bits, spindle power relay, and stepper drivers on one board with screw terminal headers would be nice and tidy..
    This any use ? https://www.ebay.co.uk/itm/DIP-Compo....c100677.m4598
    Or this ? http://www.keyestudio.com/shop/shiel...shield-v3.html
    Those breakout boards are an option, but not something I'd normally use for a finished item.
    I'm currently veering towards a custom PCB to mount the 3 stepper drivers, and the unregulated PSU bits (bridge rectifier + big capacitor), then use a DDCSV for control, which should result in a relatively compact control box that can be dragged out when needed.
  1. FOR SALE: stepper drivers
    By johngoodrich in forum Items For Sale
    Last Post: 30-05-2017, 07:21 AM
  2. Wantai stepper drivers
    By Agathon in forum Motor Drivers & Controllers
    Last Post: 29-04-2017, 01:13 PM
  3. Current favourite stepper drivers
    By GND in forum Motor Drivers & Controllers
    Last Post: 05-03-2017, 11:52 AM
  4. FOR SALE: Stepper Drivers + PSU's
    By Shinobiwan in forum Items For Sale
    Last Post: 16-03-2012, 11:05 PM
  5. FOR SALE: 3 x 2.5Amp 30V Stepper Drivers
    By michael in forum Items For Sale
    Last Post: 13-08-2011, 02:10 PM
