    From the looks of that you need to set
    Maximum Operating to 400 and
    Minimum Operating to the correct percentage of 400 to give your spindle's rated minimum speed.
    Reference Speed to 400 and
    Intermediate Speed to halfway between 400 and minimum rated speed
  2. The Following User Says Thank You to magicniner For This Useful Post:
  3. #2
    thanks thats very useful information.
    I have virtually the same setup as you but just cant get the spindle to run with any consistency. The spindle starts and slowly builds up speed but stutters and then trips out on Err 1 (Short circuit/Current overload/Power module protection). I have tried numerous combination of settings to no success. I assume you have your system running and would be grateful if you or others can point me in the right direction.
  5. #4
    Quote Originally Posted by shortcircuit48 View Post
    Sounds familiar . I'm not near the cnc till tomorrow but can paste the P1-P8 VFD settings, which might be of use.
  6. #5
    Quote Originally Posted by marbles View Post
    Thanks very much. I have subsequently connected and programmed a Teco VFD I have, but getting the same results coming out "inverter overload". I think I am doing something fundamentally wrong and keep going over the programming options to try and discover. I have an clamp meter attached and abort the start-up very quickly as current way over the spindle rating. All help much appreciated.
  7. #6
    After a bit of trial and error I have the spindle running although clarification would be good on what the intermediate frequency does.
    P00. 220
    P01. 400
    P02 15
    P03. 200. Changing this from 25 up to 200 resolved the matter. Not happy at 100 but ok at 300. Spindle starts to rotate when this value reached.
    P04. 0
    P05. 0
    P06 400
    P07. 0
    P78. 8000
    Be interested to see how your values compare.
    It suggests to me that the VFD is defaulted for a 3ph 50 Hz motor and once you come away from that various other factors come into play.
  8. #7
    LucD's Avatar
    Lives in Congleton, United Kingdom. Last Activity: 16-02-2020 Has been a member for 7-8 years. Has a total post count of 10. Received thanks 1 times, giving thanks to others 0 times.
    Im running a small surface grinder on one of these and cant seem to get the power id expect. Ive been looking for the current limit. Any idea where it is?
  1. Boxford 260VMC with toolchanger Lenze spindle speed issue/query
    By swood1 in forum Boxford Vertical Mills
    Last Post: 27-03-2018, 03:18 PM
  2. Water cooled vs Air cooled spindle for wood
    By Bucks in forum Machine Discussion
    Last Post: 06-02-2017, 01:58 PM
  3. Where to buy 2.2Kw Water cooled spindle + VFD
    By RocketBoy in forum Marketplace Discussion
    Last Post: 01-08-2016, 12:38 PM
  4. Water cooled / air cooled 2.2kw spindle
    By suesi34e in forum Generic Chinese Spindles
    Last Post: 25-02-2015, 04:57 PM
