Page 2 of 2 FirstFirst 12
    But why did the fuse blow?
    From what we read down-under, I think it may have summat to do with Brexit?
    Just replaced the fuse & fired her up - fuse blew again! The stepper controller is from a Canadian company called Larken automation.
    the odds are one or more of the transistors in a H bridge has failed short circuit (NPN bipolar in old designs or FET's in later designs)
    a shorted or broken cable would be high on my list of causes
    John
    Hi John,
    Apologies for my lack of knowledge, this is all new territory for me. I have just tried another fuse & the motor is now not making any noise or movement, the fuse is now no longer blowing. I am assuming that the short or break is most likely in the stepper motor itself, if so can I get it re-wound like a normal motor? If so does anyone know a company that can diagnose this & fix it?
  5. #15
    not sure how many companies like MASSEY COGGINS LIMITED in liverpool that rewound motors are still in business these days
    I expect too many potential customers bought new chinese motors instead of spending as much (if not more) on a rewind
    cables that are constantly are being flexed very often break just after a connector or clamp
    breaking the current through an inductive load like a motor produces a large back emf that is likely to damage any semiconductor its connected to
    after repeated replacement of the fuse its likely that either a transistor or the current sense resistor is now become open circuit
    for example if you look at figure 12 on page 14 of the data sheet of the L6208 H bridge
    the pairs of FET's H1 & L1 or H2 & L2 must never be on at the same time only as that will short circuit the supply
    one FET from different pairs can be on
    eg H1 & L2 or H2 & L1
    if a FET goes short circuit
    the current sense resistor connecting FET's L1 & L2 to the negative supply can go open circuit
    John
  6. #16
    Quote Originally Posted by john swift View Post
    Plenty, Browill Rewinds in Sheffield are my supplier of choice, but I don't think they have the equipment to re-magnetise a stepper motor after you've stripped it and killed it ;-)
  7. #17
    Lives in East Lothian, United Kingdom. Last Activity: 6 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    How big a machine is this?
    Without seeing the machine, my guess is the wiring (or connector) to the motor has failed, resulting the in the driver going pop.
    Easiest solution would be a suitable new driver, and replace any wiring between the driver and motor that flexes. It's unlikely the motor will of been damaged, but even if it has, a more modern square style motor shouldn't be that expensive.
    However, without any photos or details about the existing control box, we can't really offer much advise.
    To suggest replacements, we'd need to know what controller is being used, and the voltage the existing drives are using (along with a make/model number or a link to a datasheet so we can see what signals they need/provide).
  1. Stepper driver recommendations
    By Agathon in forum Motor Drivers & Controllers
    Last Post: 04-05-2017, 01:18 PM
  2. Recommendations for mid-range stepper driver?
    By Neale in forum Motor Drivers & Controllers
    Last Post: 11-02-2015, 12:50 PM
  3. How do I wire a stepper driver to a stepper motor?
    By swood1 in forum Stepper & Servo Motors
    Last Post: 21-09-2014, 05:40 PM
  4. Replies: 1
  5. Stepper motor help
    By Mucky Mike in forum Stepper & Servo Motors
    Last Post: 04-04-2009, 04:25 AM
