Page 2 of 2 FirstFirst 12
    looking at the circuit diagram I linked to
    this a simplified diagram of the low voltage supplies to the control circuit
Name:	XMT2360 low voltage supply circuit.jpg
    R17 is the large resistor on the board
    its value is 15 K (15000 ohms)
    in parallel with a 100K resistor that gives you a total of 13K
    if you get more than 13K then R17 will need replacing
    has R17 changed colour ?
    the resistors drops the rectified mains down to 22V at terminal K4 is linked to K3
    with K3 & K4 open circuit I would of expected you to have 200V DC
    if terminal K4 was shorted to earth
    a number of semiconductors will need checking
    starting with Z1 the 22V zenner and the 78L12 regulator IC
    John
  2. The Following User Says Thank You to john swift For This Useful Post:
  3. #12
    The machine in question is in fact my X3 mill and not the C3 lathe.
  1. Replies: 6
    Last Post: 20-12-2018, 03:40 PM
  2. Huanyang VFD and spindle problem
    By BriceO in forum Spindles & Drive Motors
    Last Post: 07-08-2018, 08:56 AM
  3. Problem with Spindle not spinning
    By Noplace in forum Spindles & Drive Motors
    Last Post: 22-01-2016, 02:40 PM
  4. seig x3 R8 V MT3
    By dazza in forum Milling Machines, Builds & Conversions
    Last Post: 18-02-2014, 01:14 PM
  5. CNC spindle control VFD problem
    By djc in forum Motor Drivers & Controllers
    Last Post: 13-09-2009, 09:26 PM
