    I have not found an exact match but this PDF wiring diagram for a
    110V mini lathe gives you a basic wiring diagram
    PDF diagram
    for the CNC conversion
    the speed control potentiometer that is normally connected to terminals p1 to p3 has been replaced by
    a DC control voltage connected to p1 & p2
    without the circuit diagram of the speed control board
    I can not guess what the blue wires are connected to and
    what possible damage to the board could of happened to the board
Name:	speed control board.jpg
    if the under side of the PCB looks OK with no blown tracks
    it will be possible to bench test the board using a 100W bulb as a dummy load in place of the motor and a potentiometer connected to P1 to P3
    NOTE - all the board & the wiring to the potentiometer will be live !!!
    repairing my CL300m lathes speed control board
    https://www.model-engineer.co.uk/for...p?th=38809&p=1
    John
    PS
    found it
    the board is a XMT-2360
    John - Thanks, the board is XMT 2360. The two blue wires are connected to the green chuck guard switch you have indicated. There are currently 3.6V across the terminals.
    Les has details of the XMT-2360 on his web site
    http://lesjhobbies.weebly.com/upload.../pcb_speed.pdf
    if your lucky R17 on page 2 has gone high resistance when terminal K3 shorted to earth
    terminal K4 shorting to earth will be of a problem
    John
    John - If the R17 has gone high. Is there anything I can do?
    Rod
    looking at the circuit diagram I linked to
    this a simplified diagram of the low voltage supplies to the control circuit
Name:	XMT2360 low voltage supply circuit.jpg
    R17 is the large resistor on the board
    its value is 15 K (15000 ohms)
    in parallel with a 100K resistor that gives you a total of 13K
    if you get more than 13K then R17 will need replacing
    has R17 changed colour ?
    the resistors drops the rectified mains down to 22V at terminal K4 is linked to K3
    with K3 & K4 open circuit I would of expected you to have 200V DC
    if terminal K4 was shorted to earth
    a number of semiconductors will need checking
    starting with Z1 the 22V zenner and the 78L12 regulator IC
    John
  6. The Following User Says Thank You to john swift For This Useful Post:
  7. #6
    The machine in question is in fact my X3 mill and not the C3 lathe.
  1. Replies: 6
    Last Post: 20-12-2018, 03:40 PM
  2. Huanyang VFD and spindle problem
    By BriceO in forum Spindles & Drive Motors
    Last Post: 07-08-2018, 08:56 AM
  3. Problem with Spindle not spinning
    By Noplace in forum Spindles & Drive Motors
    Last Post: 22-01-2016, 02:40 PM
  4. seig x3 R8 V MT3
    By dazza in forum Milling Machines, Builds & Conversions
    Last Post: 18-02-2014, 01:14 PM
  5. CNC spindle control VFD problem
    By djc in forum Motor Drivers & Controllers
    Last Post: 13-09-2009, 09:26 PM
