Thread: Seig C3 CNC spindle problem
John - If the R17 has gone high. Is there anything I can do?
Rod
14-08-2018 #2
looking at the circuit diagram I linked to
this a simplified diagram of the low voltage supplies to the control circuit
R17 is the large resistor on the board
its value is 15 K (15000 ohms)
in parallel with a 100K resistor that gives you a total of 13K
if you get more than 13K then R17 will need replacing
has R17 changed colour ?
the resistors drops the rectified mains down to 22V at terminal K4 is linked to K3
with K3 & K4 open circuit I would of expected you to have 200V DC
if terminal K4 was shorted to earth
a number of semiconductors will need checking
starting with Z1 the 22V zenner and the 78L12 regulator IC
JohnLast edited by john swift; 14-08-2018 at 01:23 PM.
The Following User Says Thank You to john swift For This Useful Post:
15-08-2018 #3
The machine in question is in fact my X3 mill and not the C3 lathe.
Huanyang VFD and spindle problem - VI/GND drawing voltage from my controller
By Mr*Beaver in forum Spindles & Drive MotorsReplies: 6Last Post: 20-12-2018, 03:40 PM -
By BriceO in forum Spindles & Drive MotorsReplies: 20Last Post: 07-08-2018, 08:56 AM -
Problem with Spindle not spinning
By Noplace in forum Spindles & Drive MotorsReplies: 4Last Post: 22-01-2016, 02:40 PM -
seig x3 R8 V MT3
By dazza in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 18-02-2014, 01:14 PM -
CNC spindle control VFD problem
By djc in forum Motor Drivers & ControllersReplies: 1Last Post: 13-09-2009, 09:26 PM
