    Hey guys, I'm new here and very new to using mill machines so I do apologise if this question sounds stupid but here goes.
    My new machine only allows me to drill a maximum of 13mm but I need to drill holes ofvatleast 19mm, is there a workaround by buying a new chuck or something like that? And I'm sorry if this is a stupid question and I hope iv posted this in the right section.
    Thank you all in advance
    Quote Originally Posted by Greeny View Post
    That's brilliant thank you very much
    I would run them Screwfix blacksmith drill bits very slowly and lot's of lubricant, they are not the toughest bits, oh and get used to sharpen them on a grinder, or if you are only wanting one size in particular, try buying one quality bit from say Cromwells etc.
    Sent from my CLT-L09 using Tapatalk
    Quote Originally Posted by scooterist007 View Post
    Thanks for the reply guys, are these kind of drill bits available where the bottom of the drill bits are flat? I need to cut a flat disk shaped hole that's all and the bottom of the hole must be flat and not domed, if that makes sense lol.cheers again
    mekanik's Avatar
    Lives in Barrow in Furness, United Kingdom. Last Activity: 17 Hours Ago Has a total post count of 803. Received thanks 101 times, giving thanks to others 176 times.
    Hi Richard
    A slot drill will give you a flat bottom hole, but RS Components want 61.45 Plus VAT and you will need a holder for it as well. you don't mention what material you are wanting to use it on ?
    Regards
    Mike
    Hi, I'm using it on stabilized wood so I'm not wanting anything that will cut through thick steel. Thank you
    Quote Originally Posted by Richardtweed View Post
    You might get away with https://www.toolstation.com/shop/p59...RoCiIkQAvD_BwE
    or https://www.wealdentool.com/acatalog...aight_239.html
    Is the mill cnc'd
    What size holes are you wanting to make? If it's not too big, use a end mill to mill a flat hole, a drill bit flute is designed to cut and draw away the swarf.
