Thread: New here please help
14-08-2018 #1
Hey guys, I'm new here and very new to using mill machines so I do apologise if this question sounds stupid but here goes.
My new machine only allows me to drill a maximum of 13mm but I need to drill holes ofvatleast 19mm, is there a workaround by buying a new chuck or something like that? And I'm sorry if this is a stupid question and I hope iv posted this in the right section.
Thank you all in advance
14-08-2018 #2
These might be of some use.
https://www.screwfix.com/p/straight-...FdqUdwodNscEAA
15-08-2018 #3
17-08-2018 #4
I would run them Screwfix blacksmith drill bits very slowly and lot's of lubricant, they are not the toughest bits, oh and get used to sharpen them on a grinder, or if you are only wanting one size in particular, try buying one quality bit from say Cromwells etc.
Sent from my CLT-L09 using Tapatalk
21-08-2018 #5
21-08-2018 #6
Hi Richard
A slot drill will give you a flat bottom hole, but RS Components want 61.45 Plus VAT and you will need a holder for it as well. you don't mention what material you are wanting to use it on ?
Regards
Mike
21-08-2018 #7
Hi, I'm using it on stabilized wood so I'm not wanting anything that will cut through thick steel. Thank you
21-08-2018 #8
You might get away with https://www.toolstation.com/shop/p59...RoCiIkQAvD_BwE
or https://www.wealdentool.com/acatalog...aight_239.html
Is the mill cnc'dLast edited by Clive S; 21-08-2018 at 05:46 PM.
21-08-2018 #9
Thanks I'll take a look at them. Would the spade end bits cut through resin? It's not a cnc unfortunately
21-08-2018 #10
