    Hi, I'm using it on stabilized wood so I'm not wanting anything that will cut through thick steel. Thank you
    Quote Originally Posted by Richardtweed View Post
    You might get away with https://www.toolstation.com/shop/p59...RoCiIkQAvD_BwE
    or https://www.wealdentool.com/acatalog...aight_239.html
    Is the mill cnc'd
    Thanks I'll take a look at them. Would the spade end bits cut through resin? It's not a cnc unfortunately
    probably
    The thing with spade bits, they have a point so still won't make a perfect flat hole.
    Sent from my CLT-L09 using Tapatalk
    Hi Richard
    You could try experimenting with the blacksmith drill recommended by greeny but grind it flat bottom, it needs to be fed slowly using a high rpm but this can only be done on a machine with fine feed control on the quill otherwise it could grab and pull itself into the job if you were to use the hand feed.
    Regards
    Mike
