Thread: New here please help
Thanks I'll take a look at them. Would the spade end bits cut through resin? It's not a cnc unfortunately
21-08-2018 #2
21-08-2018 #3
21-08-2018 #4
Hi Richard
You could try experimenting with the blacksmith drill recommended by greeny but grind it flat bottom, it needs to be fed slowly using a high rpm but this can only be done on a machine with fine feed control on the quill otherwise it could grab and pull itself into the job if you were to use the hand feed.
Regards
MikeLast edited by mekanik; 22-08-2018 at 09:32 AM.
