    Quote Originally Posted by Benja View Post
    Hey that doesnt look too bad, I'll have to figure a shopping list for RS then.
    Going to Zapp this morning to pick up the 806's :)
    Here you go.:-
    1 off https://www.rapidonline.com/vigortro...-x-25v-88-0012
    1 off https://www.rapidonline.com/50a-brid...al-case-519318
    3 off https://www.rapidonline.com/samwha-h...acitor-11-3121
    3 off https://www.rapidonline.com/lcr-ep08...-clamp-11-3004
    Bloody hell man, thank you very much. :) I think ive got a bit of AL that should do the job nicely too
    806's now installed , using a leadshine switching psu at the min and will swap out for the linear once its built :) although the switching will work fine im sure sounds like the linear will be more efficient and possibly more stable in the long run. also fun to build! :) thanks Clive for your help.
    Those drivers are night and day from the analogues I was using, motion is smoother and quiter even though ive gone from 1/10 to 1/5 Ms. Very happy but with a faint feeling I should have gone for the easy servo even though logic says this setup should be just as accurate.
    Key thing for me I think is I know these are now running at full power. The proof will be in production.
  1. TTS Tooling system
    By Davek0974 in forum Bridgeport Milling Machines
    Last Post: 23-01-2018, 11:59 AM
  2. TTS / R8 system spindle
    By routercnc in forum Drawings
    Last Post: 23-07-2017, 08:12 PM
  3. RFQ: Semi automatic welding system Linear beam control system
    By richway in forum Projects, Jobs & Requests
    Last Post: 24-01-2017, 08:54 PM
  4. Gerber system 48
    By martin54 in forum Milling Machines, Builds & Conversions
    Last Post: 13-09-2013, 12:35 PM
  5. My Coolant System
    By Tenson in forum Swarf & Chip Management
    Last Post: 08-04-2013, 01:59 PM
