    for sale as a job lot dont really want to split as it would be pick up only
    6-axis Motion Controller. CSMIO/IP-S board (step/dir), Ethernet with threading module (from memory i could not get a motor to work from channel 0)
    4 nema23 hybrid stepper motors with a spare board
    RS dinrail moutable PSU plus smaller PSU
    Huanyang spindle and control
    Case it is a Hager TPN ip rated case, perfect for an install cabinet
    A few other bits included
    Pilz unit, water pump and pipe for spindle, some wiring drag chain, wire cover, aviation connectors
    pictures attached
    any questions please ask I expect a few as the description is quite brief will update as I go
    its pretty much everything needed for a install just add frame
    Price £700 ono
    Location Telford Shropshire
ID:	31927   Click image for larger version.
ID:	31928   Click image for larger version.
ID:	31929   Click image for larger version.
ID:	31930   Click image for larger version.
ID:	31931   Click image for larger version.
ID:	31932   Click image for larger version.
ID:	31933   Click image for larger version.
ID:	31934   Click image for larger version.
ID:	31935   Click image for larger version.
ID:	31937   Click image for larger version.
ID:	31938   Click image for larger version.
    If it's pick up only you might want to mention where it is to be picked up from?
    Robin
    yeah that's very good point will edit
    sensible offers welcome
    AndyUK's Avatar
    Lives in Southampton, United Kingdom. Last Activity: 3 Weeks Ago Has been a member for 6-7 years. Has a total post count of 469. Received thanks 100 times, giving thanks to others 43 times. Referred 1 members to the community.
    Not in the market, sorry, but reading through, my only question was Spindle specs? kW and collet size would be helpful :)
    Still available?
    yes,all still for sale
    Did you get the details for the motors?
    Did you find the details? Cheers
    Quote Originally Posted by ian8415 View Post
    have replied to the PM
    small ones are 3amp large is 4 amp
  1. FOR SALE: CSLAB CSMIO/IP-M 4-Axis Motion Controller
    By Buckis in forum Items For Sale
    Last Post: 01-11-2021, 07:50 PM
  2. Hybrid stepper motor voltage.
    By Colin Barron in forum Spindles & Drive Motors
    Last Post: 11-02-2021, 11:44 PM
  3. Hybrid stepper wiring
    By gregors in forum CS-Lab (CSMIO)
    Last Post: 12-12-2020, 03:48 PM
  4. CSLAB CSMIO/IP-M 4-axis Ethernet Motion Controller
    By dudz in forum CS-Lab (CSMIO)
    Last Post: 02-01-2017, 01:27 AM
  5. Hybrid Stepper Servo
    By Boyan Silyavski in forum Motor Drivers & Controllers
    Last Post: 08-06-2015, 12:41 PM
