Thread: Using Obj. and stl. files
Thanks for your feedack - Ger21
Deskproto has Student licence with is good.
Found this comparison of the above, which was good for me. https://www.cnczone.com/forums/uncat...mastercam.html
Cheers,
ZymonLast edited by zymon; 26-08-2018 at 05:09 PM.
26-08-2018 #2
I've always been a big fan of MeshCAM since the first beta.
However, a few years ago, the developer formed Carbide 3D, and since then, development of MeshCAM has slowed to a crawl.
But it is still being developed. The current version of MeshCAM 7 was released about 4 months ago. But in it's current state, I prefer version 6.
If I ever get a machine running with a rotary axis, I'll probably invest in a copy of DeskProto.Last edited by Ger21; 26-08-2018 at 09:35 PM.
Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
26-08-2018 #3
26-08-2018 #4
No, but it has a lot more rotary axis features than anything else.
Gerry
27-08-2018 #5
I'm not quite sure if you want to convert your STL files to a 3D CAD format, so that your machine operator can then run it through his favourite CAM package, or whether you want to do the CAM yourself. I have used Fusion 360 to do the latter (and it's free if you are a student). Converting to a standard 3D file format is always going to be a little more difficult as it's not really a logical thing to do in most cases as straight to CAM/gcode makes more sense - but you need to know machine parameters like cutting speeds, cutter sizes, etc, to do it properly.
03-09-2018 #6
How would MesCAM/Deskproto compare with BobCAD? Especially the new version.
I had a look at the previous version of BobCAD and found it looked rather complicated. Can it do more than the other 2?
Zymon
03-09-2018 #7
Run away from BobCAD as fast as you can, and don't look back.
Gerry
Free CNC Vector Art Design & Pattern Files (DXF Files)
By tanvon in forum CAD & CAM SoftwareReplies: 3Last Post: 21-06-2018, 10:17 AM -
anybody got any 3d stl files they can send me
By kingcreaky in forum General ComputingReplies: 0Last Post: 20-11-2013, 06:16 PM -
400 megs of files in dxf
By Anónio Pinho in forum Computer SoftwareReplies: 8Last Post: 18-05-2012, 11:01 PM -
help needed for .drg files
By swinds in forum Machine DiscussionReplies: 0Last Post: 22-06-2011, 09:18 PM -
Help with X3 mill and XML files
By Eugene in forum Milling Machines, Builds & ConversionsReplies: 16Last Post: 12-03-2011, 01:01 PM
