    I am in the middle of my second build. I’m going for a long Z axis 500mm. 1500 x 1500 table. The z axis is getting pretty heavy. (might start a build log)
    I bought 4:1 HTD reduction belt and pulleys to give the Nema 24 566oz in a bit of extra torque to assist the Z. The X, A and Y also have 4:1 HTD reduction units. However I now realise i’m slowing the whole feeds and speeds down with reduction on the Z. The first machine was 1:1 throught
    Just looking for suggestions about other solutions before make up the nema bracket and fitting it today.
    ps got the 2DM556 drivers set on 3.8 Amps Half Current 1/10th Microstep for the 4Nm steppers perhaps could change the these settings
    What are you using to move the Z axis? Ballscrew? What pitch? How much weight are we talking about?
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
    RM1605 C7 650mm ballscrew
    700x150x12.7 alu plate for the Z travel
    HG20 rails mounted on that plate
    2.2kw air spindle
    approx total weight for travel plate, rails and spindle 12kg
    pic without guide blocks or travel plate
    I'd use 1:1
    Gerry
  5. The Following User Says Thank You to Ger21 For This Useful Post:
  1. Enhanced Ox CNC and Spindle RPM reduction issue
    By TheMike in forum Gantry/Router Machines & Building
    Last Post: 12-10-2015, 07:54 PM
  2. Z axis question
    By martin54 in forum Gantry/Router Machines & Building
    Last Post: 15-02-2014, 05:07 PM
  3. Screw Dive Size Reduction ??
    By manofgresley in forum Gantry/Router Machines & Building
    Last Post: 04-09-2013, 05:34 PM
  4. TB6560 auto current reduction
    By Mjolinor in forum Motor Drivers & Controllers
    Last Post: 08-12-2011, 09:53 PM
  5. Motor size 23' and 2/1 reduction for Z axe on SX3 retrofit.
    By A2P in forum Linear & Rotary Motion
    Last Post: 15-09-2010, 05:14 PM
