Thread: DIY Surface grinder
30-09-2018 #2
Oh , yes, very good
Here are a few questions I am pondering...
One of the best features of CNC surface grinders is that once you diamond dress the stone you know the exact height of it above the chuck. Is that information worth preserving for the next session? I'm wondering if the ON/OFF switch should apply a precision brake to the Z screw before cutting the power.
Do I need to seal all the workings dust tight or will the wipers already fitted on the linear bearings and screws suffice?
Do I need to machine the inside of the RSJ flat, to square off the rails, or will the rolled stel consistency compensate for the rolled steel innaccuracy?
01-10-2018 #3
The coolant/grinding wheel/ground metal, produces a very fine grinding paste so if wipers did work it would not be for long.
This is the minimum spec machine in terms of safety and ability to grind. It may be cheaper to buy a complete machine that needs a rebuild and fit motors on the handwheels. I paid 250 for mine and magnetic chucks on there own will not cost much less.
https://www.google.com/search?q=dron...1ZWXccBbiMtKM:Last edited by Colin Barron; 01-10-2018 at 03:43 PM.
01-10-2018 #4
Colin, I don't think you quite understand what is going on.
I don't actually need a surface grinder.
I want to play with a surface grinder.
Making it to my own design is merely the icing on the cake.
I do this for fun
06-10-2018 #5
10-10-2018 #6
What clearance bearings are you using?
11-10-2018 #7
No idea. Do you think it matters? I will be running them in an oil bath.
Surface Grinder - Elliott 618 - Any Good?
By Chaz in forum Metalwork DiscussionReplies: 2Last Post: 30-08-2018, 01:51 PM -
Spec me a grinder/belt for finishing aluminium.
By JOGARA in forum Workshop & EquipmentReplies: 27Last Post: 17-10-2017, 02:20 PM -
NEW MEMBER: From grinder to 3D printing to CNC
By laranjas3 in forum New Member IntroductionsReplies: 2Last Post: 12-10-2017, 06:59 AM -
Centerless grinder LOESER RPS 374 - in Europe
By Grinder in forum Opportunities Available & SoughtReplies: 1Last Post: 24-11-2014, 04:53 PM
