    Is there a tool to help remove stuck morse tapers from the tail stock?
    Sent from my SM-N910F using Tapatalk
    Morse taper drift?, or if (like my ML7) you don't have a slot for the drift, I normally get a piece of bar through the rear bore of the tail stock butt up against the backside of the tool and tap it gently.
    No slot for a drif. Here is my tail stock
    Maybe some sort of wedge?
    Lives in East Lothian, United Kingdom. Last Activity: 1 Day Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,994. Received thanks 376 times, giving thanks to others 9 times.
    I'm going to assume you've fitted some kind of short MT adapter that means when you wind the tailstock all the way in, the tailstock screw is not hitting the adapter and extracting it?
    In which case, suitable wedge, but you'll probably have to make/bodge something suitable. Cheap hammer/fork type ball joint extractors would also work if you find one the right size.
    No but it use to extract it. Maybe i can find a wedge that will do the job
    Quote Originally Posted by dfox1787 View Post
    It's not a hollow ended MT (aka threaded for use with a drawbar), which has been plugged, and the plug has screwed in a bit?
    If you are lucky - a tap on the chuck towards the headstock, with a soft face hammer may dislodge it. Otherwise if you can wind the quill out (after taking out the pin) you may be able to get a drift into the quill to dislodge the bugger.
    What lathe is it btw?
    Got there - Hobbymat MD65
    I've took the tail stock part and noticed I couldn't get the screw all the way through the morse taper insert. I re tapped the part and I will see how that goes.
    We alway used to (and i still do on a drill press) take two hammers and simultaneously knock both sides of the socket at the same time, even very stuck tapers will come out then.
    On a lathe there is more limited room mind you.
    I used to have a Hobbymat MD65 like yours and when you wound the tailstock in it always pushed out the taper, rather a pain actually...
  1. Replies: 0
    Last Post: 01-07-2018, 07:38 AM
  2. Laptop stuck in BOotmgr missing
    By dazza in forum Laptops & Tablets
    Last Post: 28-02-2016, 07:08 PM
  3. feedrate stuck on low
    By routercnc in forum Machine Discussion
    Last Post: 24-04-2014, 10:24 PM
  4. Morse taper drills
    By John S in forum Marketplace Discussion
    Last Post: 08-05-2013, 07:00 PM
  5. 250mW LASER stuck on
    By korky in forum General Electronics
    Last Post: 12-07-2009, 10:47 PM
