    Hi
    Im having issues with my tailstock it locks up sometimes and is a pain to sort.
    I want to take the tail stock apart to take a better look. Can anyone help?
    mekanik's Avatar
    Lives in Barrow in Furness, United Kingdom. Last Activity: 14 Hours Ago Has a total post count of 801. Received thanks 101 times, giving thanks to others 176 times.
    Hi
    Don't have MD65 but the tailstock is a relatively simple piece of kit, the quill is very similar to a drill, has a key slot running it's length and a peg in the casting prevents it from rotating, take it off the machine and strip it, it should be fairly easy to see the problem.
    Hi
    Thank you.
    I worked it out. There is a nut attached to the threaded rod deep inside the morse taper insert part. I manged to get a socket inside to hold the nut while i unscrewed the tailstock handle.
  1. FOR SALE: Hobbymat MD65 Metal lathe
    By craigrobbo in forum Items For Sale
    Last Post: 13-09-2013, 05:04 PM
  2. Hobbymat MD65
    By craigrobbo in forum Milling Machines, Builds & Conversions
    Last Post: 29-08-2012, 09:36 PM
  3. CNC style lathe home brew Lathe for drilling and cutting.
    By Bodge in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 18-04-2012, 10:45 AM
