Thread: JPG toSTL
  1. #6
    Thanks again, I did download Cura but it only seems to run on 64bit computers as does Fusion, I am only running 32 bit and am reluctant to change as my Acad 14 does not run on 64 bit.
    I can fudge it a bit by changing the Z scale on my mill and I can sand off the pimples, the pimples do add quite a bit to machining time.
    The scale is perfect for me, I am not in any hurry so if you can help when you have spare time would be great. I will see if I can remove the pimples/stars in paint.
    John
    Had a go with Paint and have removed the pimples, I thinkClick image for larger version.
