  1. #3
    Hi Adam
    what Geckodrive stepper drivers do you have ? the photos not clear enough to read the model number
    What control software are you using Mach 3 ????
    ( looking in the ports & pins you can see what functions have been assigned to the pins so you can wire the controller the same as before)
    what PC are you using ?
    assuming your machine connected to the PC's parallel printer port
    its possible that the wires where connected directly to a 25 pin D-type plug
    but I would use a breakout board & 5V power supply to buffer the outputs from the printerport and make the connections easier and avoid soldering to a 25 pin plug
    if thats a 12V fan next to the stepper drivers you are missing a 12V power supply
    John
    PS
    is this the stepper drivers in your control box ?
    do the two solid state relay switch the spindle & dust extractor ON & OFF
    with no control of the spindle speed
    some thing like CNC4PC's
    C10 break out board should do all what you need
    Last edited by john swift; 11-09-2018 at 12:27 AM. Reason: add Geckodrive G201 PDF manual & ref to C10 BOB
  1. NEW MEMBER: Production grade CNC router Vs Homebuilt CNC router advice
    By SweetAs in forum New Member Introductions
    Last Post: 16-02-2019, 12:06 PM
  2. 1st CNC Router: Overwhelmed - Some advice please?
    By wallyblackburn in forum Gantry/Router Machines & Building
    Last Post: 01-10-2017, 10:02 PM
  3. Replies: 4
  4. Looking to buy a ~4'x4' CNC router, advice welcomed
    By Franco in forum Marketplace Discussion
    Last Post: 02-06-2013, 10:05 PM
  5. Advice on which cnc router
    By Xenophya in forum Milling Machines, Builds & Conversions
    Last Post: 08-10-2012, 11:25 PM
