    John ,
    Thank you very much for all your help .
    I will order the c10 break outboard and wire as stated in the ports/pin lay out in mach3.
    Then i assume i will need the adapter you have linked on ebay to connect to the pc printer port cable. so will order those .
    the limit switches that are in place on the machine have never worked since ive had it so will get those up and running all at the same time using the attachments you have provided.
    Thanks again
    Hi Adam
    you only need to use the C10 BOB or screw terminal 25 way socket
    not both
    the C10 BOB has the advantage of buffering the inputs & outputs to & from the printerport
    also it gives the printerport some protection
    the 3 year old PC I an using to connect to the net has a printerport that works at 3.3V logic levels not the 5V levels of the old IBM PC I have for CNC projects
    when you moved the machine did you lose a 5V + 12V power supply ?
    its possible to take the supply from the PC
    John
    Hi Adam
    Just double checked and the C10 has a 25 pin plug
Name:	cnc4pc C10 BOB.jpg
    to connect it to the 25 way socket on a PC
    you need a printer extension cable with male and female ends
    not a printer cable with two male ends !
    John
    Hi Adam
    while your photo is a bit too low a resolution
    this a little more of the wiring of your box
    from what I can see
Name:	control wiring.jpg
Name:	G201 and power supply.jpg
Name:	SSR connections.jpg
    John
  1. NEW MEMBER: Production grade CNC router Vs Homebuilt CNC router advice
    By SweetAs in forum New Member Introductions
    Last Post: 16-02-2019, 12:06 PM
  2. 1st CNC Router: Overwhelmed - Some advice please?
    By wallyblackburn in forum Gantry/Router Machines & Building
    Last Post: 01-10-2017, 10:02 PM
  3. Replies: 4
  4. Looking to buy a ~4'x4' CNC router, advice welcomed
    By Franco in forum Marketplace Discussion
    Last Post: 02-06-2013, 10:05 PM
  5. Advice on which cnc router
    By Xenophya in forum Milling Machines, Builds & Conversions
    Last Post: 08-10-2012, 11:25 PM
