Although I intended the machine that Mekanik has linked to for mainly wood and maybe aluminium, I have recently been machining steel with it. Not the ideal machine, but using a small cutter (because of the high minimum spindle speed - I can run a 2.5mm cutter at 5000 rpm) I have been able to make profile cuts in 3mm mild steel. DOC is typically 0.2mm but that mainly because of the fragile cutters. I have just ordered some short series carbide cutters which should be much stiffer.
This is more "getting away with it" than using the machine within its comfort zone but it says something about the gantry design.
NEW MEMBER: Newbie with 3040 machine
By Rwoolley in forum New Member IntroductionsReplies: 8Last Post: 21-05-2017, 10:37 PM -
NEW MEMBER: Newbie on the hunt for a machine!
By Dwatts in forum New Member IntroductionsReplies: 0Last Post: 04-08-2015, 02:58 PM -
Someone to help me build a machine
By mandev in forum Gantry/Router Machines & BuildingReplies: 8Last Post: 29-01-2014, 02:07 PM -
Newbie help pls on purchacing a machine
By peacheyphoto in forum Marketplace DiscussionReplies: 2Last Post: 14-06-2013, 08:49 PM -
NEW MEMBER: newbie machine owner..
By geoff f in forum New Member IntroductionsReplies: 10Last Post: 02-04-2013, 12:43 PM
