Thread: Wrong cut
Threaded View
    Hi all!
    I have a "small" problem with my DIY CNC. For some reason, I'm not able to get the right dimensions when I cut a 40x40 mm square in wood. I get 40 mm when I cut along the wood fiber and 39.7 when perpendicular to the wood fiber.I have tried to reduce the cut deep from 2mm to 0.5 but the result is almoust the same.If I cut in mdf ,I will get 39.8 mm on one axis and 39.9 on the other(so here the differences between the axis is smaller).
    The backslash on all axis is less than 0.03
    The deflection is around max 0.04-0.05mm when 15 kg applied on each axis
    I'm running Uccnc with ETH400 and on each axis, I have a DM856.
    Also 2.2 China spindle+VDF "NowForever"(China)
    The cause of my problem can be the high noise made by the VDF. Probably I'm losing steps (when high cutting force), but I'm not sure about it.
    Any idea?
    THX
    Stefan
ID:	24835   Click image for larger version.
ID:	24836   Click image for larger version.
ID:	24837   Click image for larger version.
ID:	24838   Click image for larger version.
  1. G2 and G3 CW and CCW wrong
    By keith wainwright in forum Artsoft Mach (3 & 4)
    Last Post: 09-07-2017, 06:24 PM
  2. Doing it wrong all this time!
    By charlieuk in forum Machine Discussion
    Last Post: 22-06-2017, 08:51 PM
  3. CNC gone wrong
    By martythunder in forum General Discussion
    Last Post: 16-02-2017, 04:21 PM
  4. When it all goes wrong
    By alboy in forum General Discussion
    Last Post: 12-12-2015, 01:16 AM
  5. What has gone wrong????
    Last Post: 05-09-2014, 12:25 AM
