Thread: Wrong cut
18-09-2018 #11
What are your steps per mm settings for x and y axis ?
19-09-2018 #12
I checked this at the beginning and it was fine...320 steps/ mm, 1600 micro steps on the stepper drive, 5mm / rev on the ballscrew.The same settings for all axis
19-09-2018 #13
22-09-2018 #14
Today I discovered that my VDF was set on CCW rotation and the cutter used for MDF was a right hand one. After changing to CW on MDF I get the right dimension.
However on the wood plate on a 40x40 square it's all perfect, but when I switched to a bigger 80x80 square I get again wrong dimensions 80x79.8.
Normally it should work also on a bigger square but at least half of the issue was solved.Last edited by cncnescu; 23-09-2018 at 12:09 PM.
04-11-2018 #15
04-11-2018 #16
With such a basic error as running your spindle backwards I suggest you run through all your settings and calculations again and check X, Y and Z travel in several areas with a dial guage to ensure your calibration and and other assumptions are correct.
G2 and G3 CW and CCW wrong
By keith wainwright in forum Artsoft Mach (3 & 4)Replies: 2Last Post: 09-07-2017, 06:24 PM -
Doing it wrong all this time!
By charlieuk in forum Machine DiscussionReplies: 23Last Post: 22-06-2017, 08:51 PM -
CNC gone wrong
By martythunder in forum General DiscussionReplies: 6Last Post: 16-02-2017, 04:21 PM -
When it all goes wrong
By alboy in forum General DiscussionReplies: 2Last Post: 12-12-2015, 01:16 AM -
What has gone wrong????
By Davek0974 in forum Plasma Table MachinesReplies: 54Last Post: 05-09-2014, 12:25 AM
