    Chaz's Avatar
    I'd probably just look at teh drivers, scrap whatever control system is there and do a retrofit, cant be too difficult. The boards seem well marked, probably a good setup for an Acorn or Mach retrofit.
  2. The Following User Says Thank You to Chaz For This Useful Post:
  3. #2
    Thank you Chaz, I have another smaller machine with stepper control box too. I run Vcarve and Mach3 - would it just be a case of I could use that to run this machine and bypass the DSP ?
    Sent from my SM-G965F using Tapatalk
    PM sent
    Phill
  5. The Following User Says Thank You to phill05 For This Useful Post:
  6. #4
    Chaz's Avatar
    PM sent
    Phill
    Offer to fix it?
  7. The Following User Says Thank You to Chaz For This Useful Post:
  8. #5
    Offer to fix it?
    Hi Chaz,
    No only supplied the DSP manual and some other files.
    We changed from DSP to Mach 3 a few years ago so were no longer needed.
    I am currently trying Acorn, after a problem setting it up I now have it test running 4 axis for a router / mill and also have the lathe side running it will be made into a portable unit to take to other machines when complete.
    Phill
  9. #6
    Chaz's Avatar
    Sorry, what is DSP in this case?
  10. #7
    The DSP is the hand held controller to power this machine.
  1. NEW MEMBER: Production grade CNC router Vs Homebuilt CNC router advice
    By SweetAs in forum New Member Introductions
    Last Post: 16-02-2019, 12:06 PM
  2. Replies: 4
  3. what router can i use with openbuild ox gantry router?
    By davejavu123 in forum OpenBuilds OX CNC Machine
    Last Post: 13-08-2015, 01:40 PM
  4. eBay: CNC Router - EXELCNC HD1013 - Heavy Duty CNC Router
    By Deuce_Coupe in forum Items On eBay UK
    Last Post: 16-07-2014, 11:46 AM
